Hi my friend,
You didn't write your operating system. If your device is not out of order and set up correcly and doesn't work, then you may need its driver for your operating system.
I uploaded the driver of
Chicony DC2110 web camera for the operating system Windows 98/2000/ME/XP compatible.
If your operating system is one of the systems mentioned above, you can download it from
here. Find the file named "Chicony DC2110
Webcam Driver.zip" in the list and download it.
For windows 2000/ME/XP operating systems you will not run setup file. The driver will be installed in plug and play mode. Latest versions of operating system will
recognize your driver when you plug in the device.
First un install your current driver.
Plug in you web cam and restart your computer. When operating system asks for the driver, select the \Driver path of the unzipped driver files that you downloaded and extracted in your PC (the default folder name will be "...\Chicony DC2110 Webcam\DRIVER").
If you need help, please send your comments.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
hjn jnn zhb hbd\hdzh dh
I Need the driver of Chicony TwinkleCam DC2110 Personal Web Camera, i cant frin anywhere on web... pls need a link to get the driver
