Question about Toshiba TLP 670 Multimedia Projector
Got a light but nothing else
When I switch on the projector and connect it up to the laptop, the bulb comes on and gives me a short display of changing colours but nothing else. I don't get a menu or input from the laptop. The connecting leads seem ok.
  • Anonymous Aug 20, 2008
    after connecting up and powering up, pressing Fn +F5 does NOT put the picture from the laptop screen to the projector screen.
It seems, so the main LCD has been crashed, or not get power, or something else. The changing colours means, i think, the lcd get one picture, but then nothing. So, see the cables, inside the projector too, and see the lcd, perhaps you will find some problems. i hope, that help you.. DOMy
Posted on Aug 21, 2007
SOURCE:
I have a DELL XPS 15 Laptop. I tried to connect the laptop to different lcd Projectors using HDMI to VGA connector. The laptop could not be connected with any of the lcd projectors and no projection on the...
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Jul 21, 2011 | Epson EMP-S5 Projector
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
CP-X260 LCD Projector: when i connected to my laptop the projector does n...
By nothing do you mean it does not power on? Is your laptop on? Does it have an image on the screen?
Most of the time, this is easily fixed by holding down your function key and pressing one of the F keys. Different laptops use a different key, but you are looking for the CRT/LCD key.
So, press and hold function + CRT/LCD and you should notice a change. Be patient as it sometimes takes a moment. There are 3 settings here. One will give you a display on your laptop but not the projector. One will give you a display on the projector but not the laptop, and one will give you a display on both. So if the first time you press function + CRT/LCD you get a change but it's not what you need, try it again and cycle through until you find what you want.
May 16, 2010 | Hitachi CP-X260 LCD Projector
Sharp projector lamp will not come on
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
Feb 26, 2010 | Sharp XR-10S DLP Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Stuck in standby mode
The light bulb must be seated in perfectly, otherwise it won't see a connection and won't come on. take the bulb out, and make sure the connections don't have any dirt on it. Anything that can obstruct a connection. Give that a try.
Jan 09, 2009 | Sharp XR-10X Multimedia Projector
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Displays desktop background but nothing else
I discovered that my laptop supports two monitors and the projector was acting as monitor #2. By changing the priority of the monitors I have got the information I need on the screen, but now not on the laptop. However, I can work the two from the screen and that will suffice for the moment, until I can find a way of getting the information on both!
Sep 05, 2008 | Philips bSure SV1 Multimedia Projector
No lit / projected image even with a new bulb!
Let me add...
I had one 3300MP and removed/replaced the bulb to dust off as it was overheating. There is a small metal like switch that resets the bulb replacement (physical switch - take a good look) -- This helped to reset the first time I did this, but doesn't reset the hours on the chip.
However, since this bulb was problematic for me, I have done this a couple of times and since has stopped powering the bulb now. So, thinking it was the bulb, I replaced the bulb, -- No good... So, thinking it was the projector, I bought a new/refurbished one on ebay -- tested the NEW bulb - NO GOOD. now I have TWO PROJECTORS, THREE BULBS and NOTHING THAT WORKS...
WHAT AM I DOING WRONG?
Apr 27, 2007 | Dell 3300MP Multimedia Projector
Toshiba TLP 670 Multimedia Projector Logo
121 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
