Question about GE DBXR463EBWW Electric Dryer
Dryer starts then a few minutes later stops and is really hot
Hello..
I have a GE dryer that starts but then stops a few minutes later and the dryer is really hot. I have cleaned all lint out of the dryer and it still does the same thing. My dryer model number is DBXR463EDWW.
  • 2 more comments
  • dianafortin Oct 26, 2008
    Yes. When we put clothes in it seems to run fine and the drum turns. Then about 10 minutes later, it shuts off and the top of the dryer is really really hot and the clothes seem to be warm as if it is trying to dry. After the hurricane this year we noticed that the dryer had condensation in it before using the dryer even after a few days of not using it. I thought it was strange but because of the hurricane thought water might have gotten into the hose.
    We do have a heat setting of delicates/low heat, fluff, cottons/regular heat, and easy care medium heat. Where is the thermostat located? Also could it be both the thermostat and the motor? Thank you for all of your help and your quick responses. :)
    How can you get replacement parts? I know GE has a website. Would you get it from them? Thanks again! :)
  • dianafortin Oct 27, 2008
    For the motor there is motor and pulley assembly, strap motor,and motor support. Which one do I need?
    Genius:
  • 1,122 Answers
Is the inside drum turning?
Posted on Oct 26, 2008
  • 2 more comments
  • MIKE major Oct 26, 2008
    does it have a control heat setting,if so the thermiser thermostat is bad,if not that the motor is over heating and shutting down,you'll have to tak eit apart to chesk things out,use a puuty knife to pop the top off there is a clip on each side in the front,let me know-mike
    if you top the top look on the inside back right behind the drum and you will see the thermostat,take a look at the motor to when your in there-mike
  • MIKE major Oct 27, 2008
    go to sears. com click on parts put your model number in(inside dryer door)and you can get whatever you need-mike
  • Gilberto Santos Feb 12, 2013
    Yes, it is turning normally.
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
Gas Dryer not working properly
bad thermal sensor needs to be replace. But not available. sorry
Jun 07, 2012 | GE Dryers
GE dryer starts up ignitor gets hot you see flames everything is working. 2-3 minutes later the flame goes out. Is this a bad thermostat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101''';;
Apr 22, 2011 | GE DRSR483GD Gas Dryer
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryer over heating
It sounds like the motor is tripping out on the thermal protector.
I would start by taking the dryer apart and cleaning all of the lint out, Make sure to clean the venting.
while you have it apart look at the seals and see how worn they are.
How old is the dryer? How long is the venting? is the weather hood outside blocked?
Let me know if you have any more questions.
May 24, 2008 | GE DWSR405EBWW Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
GE DBXR463EBWW Electric Dryer Logo
435 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
