Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
I have a 48v 1000w bike kit and was told that i would get about nine mile on a charge from a sla bttery i only get about one to two miles motor get heated somewhat brand new battery from e-bike whats my problem
    New Friend:
  • 3 Answers
Weight?
Posted on Dec 08, 2012
I have a Vstar 1100 with only 10 300 Miles on the clock. I bought it 5 months ago and it started clucking when I switch off and when I start it sometimes it also clucks. Wore the battery down, bought new...
sure sounds like a starter clutch whirch a dealership will be the most expensive try finding a an independant cycle shop that works on many different brands its a simple procedure once you access the starter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2015 | Yamaha Motorcycles
I just bought a new battery for my 2005 Softail Deluxe; I road yesterday (10/20 miles) as I was finishinng the run, the bike shut off; could this mean the battery was not fully charged? Will a trickle...
Good idea put it on a trickle charge, however, the battery had enough charge init to start the bike initially, and the bike should have charged the battery after 10-20 miles, worth checking the charge rate to the battery from the rectifier,
Apr 25, 2011 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
The battery is full charged but trapidlyu loses its charge after about5 miles
Lead acid batteries can only be discharged so many times before they need to be replaced. Deep-discharging them will also seriously shorten their life.
You probably just need to replace the battery pack with a new one.
Dec 18, 2009 | Electric Bicycle Motor, Bike,electric...
Charging Issue with 1997 Shadow Spirit VT1100C
hi no way all the guy wants is money any good guy has the right test gear and would test all the charging /starter compnants before replacing the whole caboose buy youself a small cheap volt meter £5/£8 check the battery voltage start motor needle should go up to around 14 put lights on needle should not drop if this is ok then rr and stator is ok stop motor leave lights on if voltage drops rapidly battery is us hope this helps merlinv12
Aug 20, 2009 | 1997 Honda VT 1100 C Shadow Spirit
I have a 2007 v star 1100 silverado and i'm not sure if the batter is dead or there's a problem with the starter. i get a whirring sound when i push the start button but sometimes it will start if i push...
I would hate to think a bike that new would already have the start going out. Nine out of ten times when your bike won't start, it is the battery. Test it with a meter to make sure you have a good charge, I mean like 12.7 volts. It could also be a side stand switch, or wiring. Charge your battery if it isn't above 12 volts. Also when you put your bike up for the winter, either remove your battery or charge it every thirty days. This is another problem when your bike sets all winter, your batterys life gets zapped if not properly taken care of, it might not be right away, but hope this helps.
Aug 02, 2009 | 2006 Yamaha V Star Silverado
I recently purchased a 2002 vtx 1800 w/ 2400 miles on it from a friends father who never rode it. I was washing it for the 1st time and found the exhaust is melting the side of the radiator housing. It...
If the bike was not used that often,the previous owner may have started the bike in the garage,just to give the motor a run.With no air travelling over the pipes,they do get very hot.Enough to cause melting.This happens to almost any engine exhaust.(car or bike).If you run it in a garage even a household fan blowing on the pipes is enough to get rid of a lot of the heat.Hope this helps
Aug 02, 2009 | 2002 Honda VTX
1550 motor makes noises
most left hand noises invole the compensating sprocket/alternator area, and back along the primary chain to the clutch hub. bearing failure would be noticed at low rpm, so i doubt this problem has anything to do with your 1550 kit
Jun 14, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
1559 motor makes noises
CHECK everything in the primary, primary chain, adjuster & shoe, all bolts, clutch parts, and very important check alignment of primary chain. If motor was pulled from bike inquire as to if when motor put back if alignment tool was used. Good luck.
JP
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
99 people viewed this question
Top Electric Cycling Experts
Colin Stickland
Colin Stickland
Michial Gueffroy
Are you an Electric Cycling Expert? Answer questions, earn points and help others
