After attempting to install ClickArt fonts Version 4 it failed to completely install and now it locks up my computer every time I try to click on it or try to remove it from my computer
  • 189 Answers
Do you have another installer with the same version, maybe the installer have a factory defect. Try to re-install it again with new one. It's really difficult to remove the program once it locks up.
Posted on Oct 26, 2008
Clickart 400,000 compliancy
Right-click on the program shortcut =>
Run as Administrator =>
Input your Admin credentials if you have set any!
Feb 04, 2018 | Broderbund ClickArt 400,000 (385489) for...
I have a 64 bit computer and I am trying to install Parsons Hebrew Tutor which is an 8 bit program. Is there anyway possible to do this?
What OS were you previously using with the program? This program ran well under Win98 but could run in Windows XP. This is for the version released in 1997. Some reviewers noted problems with the fonts, screen resolution and color attributes under XP.
I think the only way you might be able to run the program is in a second computer (physical, dual boot or virtual). What OS are you currently running? If you have Windows7 Pro or Ultimate, you can run a virtual XP for free. (If you have Home Premium, you can upgrade to Pro or Ultimate for a fee.) Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the Hebrew Tutor on the XP computer. You may need to copy the fonts to the System font folder (either from the tutor disk or the folder that is installed with the Hebrew Tutor program)
To install a font, follow these steps in the XP system:
  1. Click Start, and then click Run.
  2. Type the following command, and then click OK: %windir%\fonts
  3. On the File menu, click Install New Font.
  4. In the Drives box, click the drive that contains the font that you want to add.
  5. In the Folders box, click the folder that contains the font that you want to add, and then click OK.
  6. In the List of fonts box, click the font that you want to add. To select more than one font at a time, press and hold the CTRL key while you select each font.
  7. Click to select the Copy Fonts To Fonts Folder check box. The new font is saved in the Windows\Fonts folder.
  8. Click OK.
(Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. If you decide to run the program under Windows 98, you will not be able to use the XP mode. Instead you will need one of the other options I have listed.
I hope this helps.
(if you are running a UNIX or MAC OS, you can do something similar with a virtual computer. For UNIX try WINE (which runs many Windows programs). For a Mac, you will need a virtualization program and a licensed copy of Windows XP.)
May 05, 2011 | Parsons Hebrew Tutor (9781572640610)
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
I want gujarati & hindi fonts for MS word file .From where can I get it?
1. Need to download all the hindi font from the site
Instructions Things You'll Need:
  • Microsoft Office CD or DVD
  • Windows installation CD or DVD
  1. Click the "Start" button, then click "Control Panel."
  2. Double click "Add or Remove Programs" if you are running Windows XP or "Programs and Features" if you are running Windows Vista or 7.
  3. Click the program list entry for the version of Microsoft Office that is installed, then click the "Change" button.
  4. Select "Add or Remove Features," then click "Next" or "Continue."
  5. Click the plus sign next to "Office Shared Features" to expand the category, then expand the "International Support" category.
  6. Click "Hindi Font" or "Universal Font" depending on the Office version, then click "Run from My Computer."
  7. Click "Continue" to finish installing the font. Insert the office disc if prompted, then return to the Control Panel window. If you are able to view Hindi fonts in Word, stop here. If you are not, you may need to enable support for complex fonts in Windows. Continue to the next step.
  8. Double click "Regional and Language Options."
  9. Click the "Languages" tab, then place a check in the box labeled "Install files for complex script and right-to-left languages." Click "OK" twice. If you are prompted to insert the Windows installation disc, insert the disc and click "OK."
Read more: How to Download Hindi Fonts to Microsoft Office Word '
If this isn't the word Gujarati: ગુજરાતી, in Gujarati then your computer probably doesn't have a Gujarati Unicode font installed and you will have problems reading the Gujarati section of this site.
Following are instructions for getting Gujarati Unicode to display properly on various computer operating systems.
Microsoft Windows Microsoft Office 2000 and Microsoft Office XP If you have a copy of Microsoft Office 2000 or Microsoft Office XP, or Microsoft Publisher 2002, and Gujarati is not displaying properly then you should install the Arial Unicode MS font which is distributed by Microsoft with these products.
If you are unsure how to install Arial Unicode MS from CD then please consult the Microsoft Help and Support website - try searching for "Arial Unicode MS".
Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 Windows 98, Windows ME, Windows NT 4.0 and Windows 2000 are not distributed with Arial Unicode MS so you will need to install an alternative Gujarati font.
You can download the following free, open source Gujarati fonts from the Indictrans Project:
Padmaa Medium, Padmaa Bold
Once you have downloaded the font file you can install using the font utility in the Control Panel, alternatively just copy the .ttf files into your \windows\fonts\ directory. There are more detailed instructions on our installing fonts page.
Oct 19, 2010 | Microsoft Windows XP Professional SP3 Full...
How to install Fonts in windows 7
hello nirav702,
To install Fonts in Windows 7, simply follow this step:
1. Download Your fonts and then unzip
2. Right clik on it and then click on properties
3. Under the General tab You will see an Unblock Button (click on it only if u see the Unblock Button, if it's not then ignore this step)
4. You can either drag and drop the font to directory: "C:\Windows\Fonts" or u can just double click on the font and install it
hope this help
Apr 14, 2010 | Broderbund ClickArt 19,000 Fonts Full...
I am trying to install creatacard 8 on windows xp home. it freezes at 8% installing fonts. i have installed this before on my computer and this time it does not work.
I have the same problem when trying to install on Vista (Home version), except it freezes at 4% intalling fonts. Have tried to adjust setup.exe properties to compatible options, still doesn't work. Also used Windows Vista compatability wizard with no luck.
Aug 22, 2009 | Broderbund American Greetings Creatacard...
Broderbund program CLICKART 950,000
Some programs do not install the full contents of the disk. Was there an option for full installation or part installation? Try running the program with the disc in your pc-the the art gallery clips may well be on the cd and not copied onto your pc even though the software program is.
Jun 10, 2009 | Broderbund ClickArt Professional...
How do I load Windows up so I can uninstall the offending program?
Try rebooting the computer and press F8 at one second intervals before the Windows splash screen shows up and select Safe Mode. If it boots try to uninstall it from there.
May 30, 2009 | Trend Micro PC-cillin Internet Security...
I have just attempted to install Kodak EasyShare version 3.3 on my computer and when attempting to use it I get the following message"this application has failed to start because the application...
Try visiting your camera's manufactures web site and they should offer this program for free via download. This will get you the newest and latest software version as well.
Sep 24, 2008 | Kodak Cameras
Computers & Internet Logo
David Payne
David Payne
