Question about Sony Playstation 3 (PS3) Console
Error 80003051E everytime i try to copy a film from my usb it comes up saying an error has accord any help with this problem?
The machine (display ) says system error e007 i dont know how to solve the problems, because every morning if i need to make a copy let say after may be three times working the message come and machine not...
You have problem with fixing film in fixing(heater)unit. The fixing film have small "white" section which is there for fixing film rotation detection.
By the problem, I would say that the withe section is + / - OK but the problem is worn out other end, and the film "dance" on the heater, so you can get few copies but when the film moves away from sensor it reports E007.
There is only one solution replace fixing film.
Hope that helps!
Dec 28, 2010 | Canon ImageRunner 2016 Copier
Tip
How to view videos on your usb in the Polaroid P32led 12 Television.
I related my earlier finding on how to put a film onto your usb to work in the Polaroid P32led 12 Television. I found that it was a VOB file?  I have now again fiddled about and found that if you install this program into your Pc:- BIGASOFT MP4 CONVERTER V.3.6.10.4437 or newer version, then setting the output format to:- VCD VIDEO (*.mpg)____Video Size:- 352 * 288cif____Video Quality:- Higher___Audio Quality:-Higher.     You then find the film for converting and copy/insert into program, then convert to desktop or folder you have made on the desktop.    This is very quick with this program. When finish and on desktop, put your usb into the computer then bring up the usb folder.   You then copy his film by left click on the film/desktop then right click with mouse then copy then take pointer over to usb folder, left click then right click in usb folder, then paste the film into it. when copied, take out usb and try in tv, should have video and sound.  just do the same again for any other films.
on Apr 17, 2015 | Polaroid Televison & Video
My canon photocopier IR2016J show error code E007. Advise me on how to resolve it or reset it
my canon photocopier IR2016J show error download and stop averthing no any function. Please advise me on how to resolve it or reset it.
Lachuo
Aug 10, 2010 | Office Equipment & Supplies
The printer display an error message E007, the printer model is CANON IR 2016i
The error E007, is a common error for digital copiers, B&W segment.It means that fixing film on fixing heater is worn out.To be exact: on left side of fixing film on heater is little white square.With help of this square, photo sensor knows the condition of fixing film.If this square is "eaten", the sensor does not recognize it and automatically reports error code E007.
Your next step should be to replace fixing film. For EU region, or 230V and 50Hz current, the part number is FM2-3353 FIXING FILM ASSY.
In case of mild worn fixing film, you can try to turn off and on the copier, and get few more copies.
If the copier has over than 500 000 copies, the best solution would be to replace the whole fixing unit.
For EU region, the part number is FM2-3352.
The condition of fixing film you can check with pocket mirror and flash light.
Open the left door, above the drum unit (long green roller) is fixing unit which have warning heat lable.Place the pocket mirror under left side of fixing unit, and you should be able to see the damadged fixing film.Also if the fixing is so badly eaten, on left door should be particles of light brown color.
But however, you should replace the fixing film.
Feb 16, 2010 | Canon iR 2016i Black and White Copier
Says error everytime i try to calibrate tony hawk wii game
we are having the same problem says error everytime i try to calibrate the tony hawk wii game
Dec 26, 2009 | Nintendo Wii Console
After making film, can't open the file *ppp again
Did I understand properly if I say : After 2 weeks yu cannot find your film in your camera and the Power Producer says that some files properly does not exist ??
If yes then :
1. :check that you not have renamed the files (ex. record 1015 to my child 1). some cameras cannot understand that you rename the files inside the camera, you need to copy them out and then rename them. If you have done that then you can use explere to search inside your cameras hard disc and find the renamed film files.
2. :Another thing could bee that you have too many USB connected to the computer ( the computer can only have a x nummer of USB connected to the pc at the same time), try to disconnect some of the other USB connected.
3.: The USB place (port) you use for the camera is not working properly, try to use anither USB connection
4. The film files are corrupted( there can bee different reason for that ex you just disconnect the vire connected to the pc and camera without first disable the USB connection) OR the camera do record over the the old film when there is no more space or after a certain time.
For this thin you can try to recover the file with Recuva, here is the link :
http://www.recuva.com/
5. The battery in your camera is nearly empty, for this recharce/ by new ones (it depend if you use Rechargeable batteries)
Hope that helps, if not return here
Please rate my answer
Sep 04, 2009 | CyberLink PowerProducer 2 for PC
Sansa E260 Long Start Up and Ask Language
I'm not sure it will solve the problem but try updating the firmware It may not help but certainly won't hurt. Set USB mode to MTP.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Mar 27, 2009 | SanDisk Sansa e260 MP3 Player
DVD not copying
Try a different media brand.
Dec 30, 2008 | Roxio Easy CD & DVD Burning
Dvd
First you can try a different CD/DVD burning problem.
If that doesn't help you might need a need CD/DVD burner as the one you have is all burnt out.
If you need more help just comment.
Aug 14, 2008 | HP Computers & Internet
Sony Playstation 3 (PS3) Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
