Question about Sewing Machines
My mammylock overlocker is skipping stitches regularly on the chain stitch. It overlocks perfectly. Can anyone help?
5 Suggested Answers
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
SOURCE: I cannot get the chain
I went to fixit.com and found the answer
Posted on Dec 07, 2008
  • 46 Answers
SOURCE: My Evolve serger is skipping stitches while using
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Posted on Nov 27, 2009
Testimonial: "Thanks I am going to try this as soon as I can, but right now occupied with a job with my industrial machine. My only issue may be with the needle."
  • 371 Answers
SOURCE: 4 thread overlock --right needle skipping stitches
Sounds like the loopers are slightly out of line or the needle bar is twisted. Unfortunately these adjustments are not easily made. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
My overlocker is skipping stitches, I have re threaded it and replaced the needles and oiled it, it is still skipping stitches. any ideas as there is nothing else in the manual to tell me what to do>
Check to make sure you have the right needles and that the thread and needles are compatible. Usually, coverstitch machines use a slightly longer needle than overlockers and sometimes people get them confused. Also, it might have something to do with the fabric you are overlocking. Try stitching a different kind of fabric and see if it is still a problem.
Mar 09, 2015 | Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
Coverlock skipped stitches
I'm assuming this is a domestic overlocker machine and not an industrial coverlock. Getting the coverlock stitch to sew out evenly without skipping can be problematic apparently with these.
First, if you are sewing a knit fabric, change the needles to ball points and see if this resolves it.
If not, I would suggest trying EX705 needles (assuming that your machine takes the regular domestic 130/705H needle system). The EX are just extra long scarf at the back which helps with securing the stitch on the underside. There is also a SUX needle, which is same long scarf but a stretch needle; for knits particularly those with elastane in them.
Thread wise, try Maxilock brand. You may find a wooly overlock thread on the underside works too.
Nov 09, 2011 | Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
My Evolve serger is skipping stitches while using the 4 thread safety stitch which is a chain stitch with a two thread overlock. Sews fine for a few stitches and then skips a loop which unravels. I checked...
Nov 20, 2009 | Baby Lock Evolve
Bernina 1300 dc overlocker skipping stitches
Rob
Mar 14, 2008 | Sewing Machines
Sewing Machines Logo
95 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
