Question about Ricoh Aficio 1027 All-In-One Laser Printer
Is it possible to setup scan to folder on my afficio 1027
  • Anonymous Mar 21, 2012
    IF you have the scanner option on your machine, then you'll need a software called Scanrouter V2 lite, which can be difficult to find, since it's not been supported since 2003. Then, You also need some knowledge of how to configure it as it is a proprietary software from Ricoh and is quite quirky - especially if you're running windows Vista or 7. With all due respect, I would suggest the only way you'll get it to work is if you find a local dealer with some knowledge on this older model to set it up for you.
    I happen to be located in Toronto, CA
  • 3 Answers
Cannot set up the scan to folder because that machine cannot put a hard disk that used for scan to folder just only can use the network twain
Posted on Dec 23, 2013
How do i scan and send to email
Scan setup. create a folder on c drive of computer example called scan. then share folder with everyone and make sure it has read/write permission. Then on copier push button says user tools/counter then system setting/administrator tools/ address book management /new program / enter a name then go to folder smb then browse for computer select it. then will ask to log in. which is log in name and password that you use to log on computer with. Note user name needs to be letter or numbers only no symbols or spaces. Example user name: scanner password: scanner123 then select scan folder and press ok then press ok again to save setup.
Sep 30, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Did ricoh can scan anything
The 1027 can be equipped as a scanner, but there is a special module the copier needs to have installed. A quick way to check if it's been installed is to look at the function keys to the left of the touch screen. There should be a key for Copy, and maybe one for Document Server as well. If you see keys for Printer and Scanner, then you have the ability to scan and you just need to configure the settings. Otherwise, you'll have to purchase the print/scan kit in order to be able to scan.
Aug 04, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
MY RICOH AFFICIO 1027 JAMMED AND SHOW SC542
SC542 A Fusing temperature warm-up error The fusing temperature does not reach the standby temperature within 20 seconds after the main switch is turned on. • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermostat open • Power supply board defective • Poor connection of the fusing unit
Apr 16, 2010 | Office Equipment & Supplies
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Oct 07, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Can't save my scans in pdf form
This can possibly solve your problem:
0. you should have the CD that came along with the printer. the solution that is listed below is working for windows xp operating system.
1. Browse the CD -> Go to the Setup folder. -> Go to the DocProc folder. -> Double-click Docproc.msi to install. you will not see any progress etc.,
2. Browse the CD -> Go to the Setup folder. -> Go to Qfolder . -> Double-click Qfolder.msi to install. same as above.
3. Go back to your HP solution centre and under scan settings option you shhould get to see the PDF options (and a few others as well).
cheers
Apr 14, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ricoh Aficio 1027 stopped working
You were able to scan okay before? If you can print but not scan, generally it's a firewall or permission problem. You could try creating an exception for the Ricoh in your firewall software.
The folder that you scan to hasn't moved, has it? Is the path still exactly the same? Try turning off your firewall and/or anti-virus software and see if you can scan then.
Mar 17, 2009 | Ricoh Aficio IS420 Flatbed Scanner
Scanning problem
Make sure the HP Digital Imaging Monitor is running in the system tray at the lower-right corner of the computer screen. If it is running do a right click on it and see if it has your printer listed on it.
If Digital Imaging MOnitor is not running or your printer is not listed when you do a right click, it means that the printer softwares is not installed properly.
You will have to complete clean up the HP printer softwares and reinstall the software.
Apr 09, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Re: SCANNING ON RICOH
You need the scan router lite utility. You can download it from:
http://support.ricoh.com/html_gen/util/SR/SR_R.html
Feb 22, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
280 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
