WE WILL HAVE TO RESET SHARP FAX FO-50. PLEASE RESPOND
WE WILL LIKE TO KNOW THE PROCEDURE TO SOFT RESET THE SHARP FAX F0-50 & ITS SCANNER IN INDIA
SOURCE: Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Posted on Jan 16, 2008
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
SOURCE: sharp fax
i dont know how to send a message using fax machine
Posted on Aug 08, 2008
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
  • 48 Answers
SOURCE: sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
Need manuel
hi just
try try this link then download
http://esupport.sharp-cee.com/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=36&SortOrder=DESC&OrderBy=Title&SearchString=fo%20dc%20550
Apr 21, 2011 | Sharp FO-DC550 Laser Fax
MANUAL SHARP FO-50 FAX/PHONE
my sharp fo-5o donnot what evrytime cover ope???
Jul 05, 2009 | Sharp Office Equipment & Supplies
SHARP F0-4400 Need to lower baud rate to 9600 on
Don't do it, it will make your machine extremely unreliable.
Fax machines are ANALOG devices and will not work on a DIGITAL phone line.
Jun 26, 2009 | Sharp FO-4400 Fax
Sharp F0-5700 Fax No Paper (Tray)
Remove the tray out of the copier and look for one next to the feed tires.
Jan 08, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp fax
Jul 07, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
49 people viewed this question
k24674
