Question about Polaroid Televison & Video
Whats a LVDS cable - Polaroid Televison & Video
    Scholar:
  • 120 Answers
Low-voltage differential signaling (LVDS) Allows very fast transfer of signal. Used in LCD, some plasma TV,s and Monitors. If the cable is bad it cause many image display issues similar to the pic. More info about T-con Control Boards and LVDS cable
Posted on Feb 18, 2012
LVDS flat ribbon cable. full description needed
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 02, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Olevia 232 t12 lvds cable
It might be best to replace the LVDS cable along with T'Con.
Jul 09, 2013 | Televison & Video
Any tricks to replacing the LVDS cable in Samsing LNS4051DX/XAA
Its easy but be sure the set is unplugged. The LVDS has little tabs that are on each side of the metal connection when you press in on the tabs the lvds cable slides right out of the Tcon and the other end does the same on the main board. To plug it back in press in the side tabs and then slide it squarely into the socket on the TCon and then release the pins when the connection is all the way in. 2_13_2013_1_58_03_pm.jpg
Feb 13, 2013 | Samsung LN-S4051D 40 in. LCD Television
Problem
I would say either the main board or the LVDS (cable from the main board to t-con board) cable. Could be other things but I would start with having the LVDS cable checked.
Feb 03, 2013 | Televison & Video
Today my 55" vizio screen popped and then turned red. I unpluged and restarted everything and now the audio is on, the chanels change, but the screen is completely read. some images are readable.
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
Dec 09, 2012 | Vizio VO47L 47 in. LCD TV
I dropped my laptop in my garden and had trouble closing it. I thought that a piece of mulch had gotten trapped in the hinges so I tried to get it out. Unfortunately, I cut what I believe is the...
isight Camera Cable:http://www.powerbookmedic.com/MacBook-Pro-17-iSight-Camera-Cable-p-19553.html
If you've lost video:
LVDS Cable
http://www.powerbookmedic.com/Macbook-Pro-Display-Cable-LVDS-17-Models-p-17115.html
Nov 09, 2012 | Apple MacBook Mac Notebook
How to replace lvds cable
The LVDS cable has a small tab on either side of the connector which gets pressed in so the connector can be slid out of its socket.
Feb 11, 2012 | Vizio VO47L 47 in. LCD TV
Aluminum G4 15'' display with 3 bands. Good top, black middle, white bottom. Any idea what I need to repair this issue? Model # is A1095
You can eliminate the graphics processor as the problem by attaching an external display or TV (using the required adapters) and seeing if the image there is OK. Frankly, it's much more probable that you have a display hardware problem, either a bad LVDS cable or a bad LCD display. If you're very lucky, the problem is just a loose connector at one end of the LVDS cable; otherwise, there is no way to determine which is the problem without trying both. The LVDS cable is relatively inexpensive compared to the display upper. The display upper is sufficiently expensive that repair on a unit this old, while perfectly possible, may not be cost-efficient.
Oct 08, 2009 | Apple Computers & Internet
I need a lvds replacement cable for a ltv-32w3hd
try these kind of lvds cables,if some of them fit for your need.
Jul 02, 2009 | LG 50PG30 Plasma HDTV
Televison & Video Logo
515 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
