Question about Xerox WorkCentre 220 All-In-One Laser Printer
Solution for xerox workcentre pe220 scanner locked error
  • 2072 Answers
SOURCE: cannot remove "scanner locked"
What you need to do is look in the area where your copied pages come out, Between the paper tray and the bottom of the scanner.
On the underside of the scanner you will see a green latch, It is the only green item on the underside of the scanner. About 2 inches long and a half inch wide.
Turn off the machine, push that lever in, then, and it may resist some, pull it toward yourself until it snaps fully to the front of the machine.
Normally what happens is people hit it with the top of their hand removine their copies.
You can take a piece of electrical tape or duct tape and put over it to secure it in place.
You can also, remove the seal glass, the piece of glass about 1 inch wide on the left side of the scanner. It just has 2 phillips screws in it. This with the machine unplugged, and pop that green latch out and flip it around. There is a tab that will keep it from moving. That latch is for shipping purposes.
Posted on Mar 06, 2008
  • 2072 Answers
SOURCE: LSU Error
I will simply send you what the documentation states ok?
Either a laser main board or loose connection to either.
  1. Check the wiring between the LSU and CN5 on the Main PWB.
    1. Install new components as necessary:
    2. LSU, PL 6.10 Item 1.
    • Main PWB, PL 1.10 Item
  • Posted on May 26, 2008
    • 59 Answers
    SOURCE: xerox workcentre PE220 paperport install only
    Dear user,
    pl find paperport software from this url.
    www.support.xerox.com
    Regards,
    Ravindra Shah
    Posted on Jun 29, 2009
    FixinFax
    • 3085 Answers
    SOURCE: lsu error in xerox workcentre pe220
    You have a bad LASER SCANNER UNIT
    Posted on Jul 07, 2009
    • 5 Answers
    SOURCE: how to unlock scanner in xerox pe220 printer
    u have to move latch near scanner unit to unlock position
    Posted on Dec 14, 2009
    The printer says the scanner is locked and won't print or copy. How do I Unlock it.
    OK this answer you won't like,
    For one there is no scanner lock on this device (not sure why the machine generates an error pertaining to that), 2nd and I assume you already tried turning it off and on and no improvement.
    What the error really means to tell you is there is something wrong with the scan head movement or sensor. When you make copies there is a scanner head the moves over your original and captures that image, chances are if the reboot of the device doesn't fix this then your scanner head has come off the rails , kind of like a bicycle chain coming of your bike it must be put back on to move the bike...
    You need to get the scanner head put back on the rails, This will require a Xerox trained service technician to repair, if you don't have a maintenance agreement on the PE220 you may want to call Xerox or the person you bought the device from to see what your options may be, may be too costly to have someone come onsite to repair ...????
    I hope this helps...
    Mar 08, 2015 | Xerox WorkCentre PE220 Multifunction...
    Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
    Iffi,
    Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
    Mar 22, 2011 | Xerox WorkCentre PE220
    LSU error in XEROX workcentre pe220. What is the
    R/sir,
    I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
    Thanks and regards
    PK Jain
    (Pennywise)
    Dec 15, 2010 | Xerox WorkCentre PE220 Series
    My workcentre pe220 printer's scanner is locked
    my workcertre pe 220 scanner locked . how can i scanner unlocked?
    Sep 03, 2009 | Xerox WorkCentre 220 All-In-One Laser...
    Xerox PE220 scan
    you do it by install the driver and then the scanner cd and you have the possibilte to scan via pc
    Feb 21, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
    Xerox WorkCentre 220 All-In-One Laser Printer Logo
    707 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
