Question about Cell Phones
My Samsung Headphone problem
When i unplugged headphone then not play in loud speaker
  • 355 Answers
Thats a problem with your software. Update your phone software to get the problem fixed. thamks.
Posted on Feb 18, 2012
Bajanguru
  • 7752 Answers
SOURCE: Samsung SPH-a660 seem stuck in
do a hard reset *2767*3855#
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: music from my dare only plays out of one headphone
To reset it just reverse what you did before it went out, example, headphones plug in and it comes out real quick now theres no sound, turn off the phone and plug the headphones back in and turn on phone with headset in 3.5mm jack then unplug after phone has fully rebooted and ready for use.Trust this works cause i ve done it a many of time since i hooked it up to my car to listen to music. ps did you know you can change the sound effects under the menu while the music is playing to different types of bass levels.
Posted on Jun 12, 2009
  • 523 Answers
SOURCE: Headphone jack not working
Hi Friend,
The problem is with your head phone it may not correctly connected,kindly check it out or replace with the other headphone and check it.
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Posted on Aug 02, 2009
  • 212 Answers
SOURCE: How to configure bluetooth headphone to play music?
This phonr doesnt support A2DP profiles, so u cant play songs throgh bluetooth headset
Posted on Sep 04, 2009
SOURCE: Samsung E250 Headphone Problem
its the headphones they are very fragile youll need to buy some more
Hope ive helped
Posted on Nov 11, 2009
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
Connect my BA7800 to my laptop that only has a headphone jack
As you stated in your question there are 3 3.5mm headphone jacks connected to the speakers. Green is for headphones, red is for microphone, and black is probably just a line in connector.
plug the green connector from the speakers into your headphone port on your laptop and it should work.
because the speakers are self powered and have a few adjustment knobs on them, you will have to tinker with the volume coming from the laptop and from the speakers, so you don't have distorted, scratchy sound from the speakers when playing music at loud levels.
my suggestions is turn the laptop volume down to a quater of the volume and then turn the speakers up, let the speakers do the hard work and not the laptop..
Jan 04, 2015 | Boston Acoustics Audio Players & Recorders
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
My laptop's audio software is installed correctly. it is working well in headphone but when i unpluged the headphone leaptop original speaker is not working
the problem is likely your speakers. consider the extension speaker or speakers use the function bound to perform troubleshooting
Mar 09, 2012 | Dell Computers & Internet
Cant hear anything when i answer the phone . the person ringing me can hear fine.
In order to check your mobiles capability to modulate sound just put your headphone. If you are able to hear the speech through headphone then the problem is with your speaker. If unable to get the speech the problem is with main pcb itself and to repair that you will have to go to service center it will be costly but if you are able to hear through headphone then it will be cheap.
Apr 13, 2010 | Samsung U900 Soul Cellular Phone
My headphone port is not working in my acer aspire5710z laptop. when pin is inserted in the port, still then the inbuilt speakers are playing, not the headphones or external speakers.
Do the following:
Turn off the laptop, unplug power cord and remove the battery.
Put back laptop together, and restart the laptop with headphone jack in. Restart the laptop with headphone in twice.
Third time , while laptop is on, unplug the headphones and restart laptop again.
This will usually fix the headphone problem on Acer laptops.
Sep 10, 2009 | Computers & Internet
Fuzzy (unclear) sound
UNPLUG YOUR SPEAKER AND REPLACE IT WITH A HEADPHONE, IF THE SOUND IS THE SAME THEN UNINSTALL THE DEVICE [SOUND] AND REINSTALL, IF YOUR HEADPHONE SOUNDS RIGHT, THEN THE PROBLEM IS IN YOUR SPEAKER... PLEASE VOTE FOR MY POSTING
Oct 28, 2008 | Harman Kardon SoundSticks Computer...
I plugged headphones into my samsung sch-a930 and now that the headphones are unplugged i cannot hear phone calls or music without the headphones
I think you just plugged an over size headphone jack...
OK, play music and try to plug and unplug several times.
if sound heard form phone just leave.
otherwise get replaced the headphone socket.
Apr 19, 2008 | Cell Phones
No sound
See if it works with the headphone jack instead of speakers.
If the sound is intermittant on the headphone jack too then the headphone jack is broken causing the speakers not to work. You could probably find a place to solder the jack.
If it works fine on headphones then either the speakers are bad or the amplifier on the mainboard has failed.
Dec 24, 2007 | Samsung X05 Notebook
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
