Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Refrigerator and freezer isn t getting cold
  • 3 more comments
  • jimcrow47 Oct 26, 2008
    ERE
    i don t understand what u mean about the compressor but the fan is working top and bottom
    the big black thing in the back u r talking about is it call a embraco that might just be the brand well its hot but its not vibrating or humming .i can hear the refrigator on
  • francis rivero May 11, 2010
    is the compressor running? are the fans running? top and bottom?
    tnx 4 asking,
    drcool
  • Anonymous Apr 01, 2014
    Frezzer and frig isn't getting cold sounds like its running but wont get cold
  • 958 Answers
ERE ???
Posted on Oct 26, 2008
  • francis rivero Oct 26, 2008
    ok..take a look at the bottom back. there is this big black thing that hums, see if it vibrates, and very hot ( be careful).. if it does not hum, it is not running. turn it off , let it cool. and plug it again after 12 hours. then check if it is running now.
    tnx 4 using fixya,
    drcool
    ok..so that could be your problem..it is over heated and stop working for a while. un plug it for about 4 hours, just to coll it down a bit. then re plug it and check if it would run. check also the fan near the compressor if it is running, it should run if the compressor is running. check also your setting of thermostat. see if it is low enough to trigger the compressor on.
    tnx again,
    drcool
heatman101
  • 43501 Answers
SOURCE: refrigerator is not getting cold freezer is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 20, 2011
TheMobilian
  • 8205 Answers
SOURCE: My refrigerator isn't staying cold nor is the
Look and see if coils need cleaning below. Do a good clean. Feel the compressor, if it's hot to the touch or cold it may have a bad relay. A relay can fail to drop circuits (causing the compressor to overheat) and open (causing the compressor to be idle).themobilian_2327.jpg
Posted on May 09, 2011
heatman101
  • 43501 Answers
SOURCE: I have a GE Model GSS22SGRF refrigerator. The
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
  • 1156 Answers
SOURCE: freezer isn't cold, defrosted all of my food
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Good luck
Posted on May 31, 2011
heatman101
  • 43501 Answers
SOURCE: freezer is cold, refrigerator isn't
heatman101
Posted on Jul 26, 2011
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
heatman101
Sep 03, 2011 | Samsung Refrigerators
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Freezer is cold, refrigerator isn't
heatman101
Jul 26, 2011 | Refrigerators
I have a sharp refrigerator - freezer. SJ-48L-SL1 The freezer is colding but the refrigerator section isn't.
heatman101
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
heatman101
May 23, 2011 | GE Refrigerators
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
170 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
Shafky Khan
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
