Question about Zyxel P660HW-D1 Router
Bad WIFI reception
In certain parts of my house i cannot get WIFI reception on my laptop .Is it possible to fit an aerial extention to the router
    Genius:
  • 1,269 Answers
Yes. You can just deploy a Wireless Access Point or a Wireless Range Expander. What they do is they extend your signal from main router thus, if you're having low reception at one part of your house, deploy the Wireless Access Point there and it's gonna give you another excellent signal.
Posted on Oct 28, 2008
How can i boost and speed up my Wifi network reception ?
Firstly download WiFi Analyser from Google Play store and compare you WiFi with others in your area. This will enable you to change the channel. Change channel by logging into your router - 192.168.1.1.
Try moving your router to a more central place in your home and use the analyser to check if any improvement.
Next try a wireless extender. This will drop your speed a little but give a stronger signal in weak areas.
Also try power line adapters.
If you are using a few devices ensure that you are not mixing wireless g and n products at same time. Using a g product will mean that your whole wireless will be running at that speed even when your other device is n. If you need both connect another g router to one of the n router LAN ports with dhcp disabled. That way you can have the two devices connected at the correct speed.
Some routers will let you connect a bigger aerial which could boost you reception. Some devices have very poor wireless antennas - seems you what you pay for in this area.
Apr 16, 2014 | Android Apps
Tip
Improve wifi reception and av transmitter quality
<span>To create Your windsurfer you need to cut out he following template, cut it out and cover the large square shape with foil which is glued on<br /><br />Template<br /><a href="http://www.freeantennas.com/Templates/windsurfer.jpg">http://www.freeantennas.com/Templates/windsurfer.jpg</a>. <br /><br />To create this shape:<br /><a href="http://gallery.me.com/andrewgc1988/100009/Windsurfer1/web.jpg">http://gallery.me.com/andrewgc1988/100009/Windsurfer1/web.jpg</a><br /><a href="http://gallery.me.com/andrewgc1988/100009/IMG_0782/web.jpg">http://gallery.me.com/andrewgc1988/100009/IMG_0782/web.jpg</a><br /><br /><br />When aiming with the windsurfer it means that the foil is facing when you want to improve reception.<br /><br /><br />Wifi reception you will need one or two windsurfers depending on number of aerials.<br /><br />To improve wifi reception you need to slot the arial of the router through the x's and aim it so that it covers the area you want to improve reception.<br /><br />Av transmitters will need two windsurfers one for the transmitter and one for the receiver. <br /><br />You need to slot the aerials through the x's and try and aim the transmitter towards the receiver and the receiver towards the transmitter.<br /><br /><br /><br />Although this won't be a miracle it will reduce interference</span>
on May 29, 2011 | Computers & Internet
Tip
Improve wifi
on May 29, 2011 | Televison & Video
Poor reception on some digital channels
If possible either move the set to a room with no reception issue to see if same there or move another set to where this one is.
Usually a set does not have a problem if only certain channels.
Swap the set(looking for loose or damaged connection where cable crimps to fitting) if you can.
Mar 19, 2012 | Televison & Video
I just bought a laptop and I wanna connect to wifi how can I do it?
First you must understand that wi-fi only works within a certain distance from the wireless router. It's not like cellphone reception where the wireless provider installs cells throughout the countryside to make sure that you can get reception. You have to either get your own internet connection to your house and your own wireless router, and then you have to install the wireless router, or you have to go to a coffee shop or other establishment (public library?) that provides its patrons free wireless internet while they are on the premises. Once you do one of those two things, then (in Windows 7) you have to click on the network connection icon in the lower left-hand corner of the screen, then click on the name of the wireless network that you want to connect to and click "connect", and then if prompted, type in the network key for that network. After this, you should be connected to the internet wirelessly as long as you are within range of that wireless router.
Mar 01, 2012 | Dell Computers & Internet
I am using my computer about 40 metres away from the Thomson5BF744 modem supplied by Telecom, at this distance I cannot connect to Internet, I can connect to Internet within 15 metres just with low signal...
You can use repeaters which you can place midway between you and the WiFi access point.
Take a look at http://reviews.cnet.com/4520-11334_7-6271405-5.html to have an idea of how it works.
With strategically placed repeaters, you can cover very large areas efficiently.
May 01, 2011 | Thomson Computers & Internet
I get bad reception with my TP-Link PCIe Wifi Card! What can i do?
Often times the antennae on these routers come loose. Ensure that the antennae are firmly plugged in.
Try also changing the channel. Routers have 11 to 13 possible channels and most default to 1 6 or 11. Try a different number to reduce interference.
Physical construction of your house can hinder wifi reception. This is often subjective and your best bet would be to move the router around the room or into a different room if possible.
Feb 28, 2011 | TP-LINK 11b/g Wireless Adapter
I only have two bars on my wireless network and would like get a better connection. I would like to surf channels to see if i can get better reception
Try placing the router closer to the center of the house, and in a higher area, and away from cordless phones, and high voltage wiring.
Aug 31, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Bad reception
If your old router has an option to become a relay for a specific Access Point.... most do not have that option unless its a 3rd party firmware
Apr 28, 2008 | Draytek Vigor 2600We (Vigor2600WE)...
Poor Wireless Reception on DELL Inspiron
It is likely your wireless card reception. try an external usb wifi adapter it shouldn't be expensive.
regards
Mar 01, 2008 | Linksys Wireless-G Broadband Router
Zyxel P660HW-D1 Router Logo
208 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
