Question about Sony Handycam CCD-TR517 Camcorder
Picture with playback ,but no sound
No sound to the tape when playing back
  • 2 more comments
  • Any Guy
    Any Guy May 11, 2010
    Sorry that last bit was meant for another post, please disregard it.
  • Any Guy
    Applying voltage to the loading motor while it still connected to the camcorder drive circuitry is a BAD IDEA!!! You are libel to fry the drive circuits that feed the loading motor and cause more problems than you currently have. Your best solution is to take the camcorder to a qualified service shop.
  • Any Guy
    There are several things that would cause the no sound issue, but the most common in Sony 8mm camcorders is a misalignment in the tape guides. As the guides become misaligned, first the sound will go and then noise will begin to develop in the picture. If you are beginning to see noise at the top or bottom of the picture, it is likely the tape guides are moving out of alignment. That would be my first best guess. Unfortunately, the best solution is to have a technician with an oscilloscope and an algnment tape check your tape guide algnment.
  • Any Guy
    Is this on all tapes or tapes you have just recorded? Do tapes that you know had sound in the past playback now with no sound?
Thanks for quick reply,dont,tapes that i knew had sound before are now silent.
thanks liam
Posted on Oct 26, 2008
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
My jvc hr-s8700 has no hifi stereo playback
The VCR stereo playback sound is only available through the AV/SCART connection and will not work through the coaxial antenna cable.
Cheers
Jan 08, 2009 | Televison & Video
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Playback not working
Hai, Clean Video Head with Head cleaning Cassatte & check the picture. udupi M/s.Prathiksha Electronics
Mar 18, 2007 | Canon MV450i Mini DV Digital Camcorder
Sony Handycam CCD-TR517 Camcorder Logo
147 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
