Question about Nokia N72 Cellular Phone
Hanging the phone n72 when insert sim card.
When I am insert the sim card. After I switch on the phone and then after starting the phone my.. cell is hanging up...I can't insert any sim card because of this problem. even there is no sim card at that time my cell phone is not hanging..plese solve my problem....
  • chirag_balar
    chirag_balar Feb 18, 2012
    I also inserted all sim cards...and there is no guaranty of this phone. because i have this mobile from last 4 years..and i have given it for service.. but there is no solution..ok. and thanks for give suggestion.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Your phone had a network ic i think it is the culprit here replace it with new one
Posted on Nov 22, 2012
  • 355 Answers
Try with any other working sim. if still there lies the problem, try updating phone software . may be the problem gets solved. if still the problem persists take it to the service center to get the sim reader replaced. thanks.
Posted on Feb 18, 2012
SOURCE: How can I open my nokia n72 phone to insert a SIM
just turn backside ur mobile you will see the small oval shaped button below .just press it with ur nails and pull downwards.urs back side panel opens .just simple
Posted on Jul 28, 2009
mixmaster
  • 626 Answers
SOURCE: sim card rejected / insert sim card
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
Posted on Sep 12, 2007
shanth
  • 108 Answers
SOURCE: Insert Sim Card
1. its mainly due to Sim card get older and bend. So it cannot seat well in its slot.
2. Remove the Sim card. Check whether Sim card is normal. Due to the dust on the Sim also can cause this problem
3. May be the phone's Sim slot pin allignment problem. Check whether the all pins are good.
4. Some times when phone falls to the ground makes the Sim move from its slot. So also this problem occurs.
5. if problem persists even after these diagnosis methods.
6.Contact service centre for further Rectifcation. thank you
Posted on Dec 24, 2007
entchana
  • 79 Answers
SOURCE: Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Posted on Jul 27, 2009
CPU solution
  • 164 Answers
SOURCE: nokia 2600 says insert sim when sim card is in
you may either have your sim card not seated securely or maybe just a bad phone or even a bad sim card if i were you i would contact your local cell phone retailer they will be able to help you further!
Posted on Dec 19, 2009
MY NOKIA N 72 MOBILE HANGING WHEN STRAT MOBILE
Dear Friend
If You Do Not Made A Reset Just Do Reset You PHone By Using This Hard Reset Code But Before That Copy You Contact & SMS in Sim memory because after that might be it will get lost
Switch off the phone
pull out the memory card
sim Card
& then
type this code
*#7370#
After that start the phone without memory card
sim Card & Setup Settings & then switch it off and insert all the things
(advice)
But unnecessary contain should be out from your mobile time to time and virus scan after 2 weeks it keeps you golden mobile for life time faster smoother and working
your friend
samadhan
Aug 01, 2011 | Nokia N72 Cellular Phone
Hi i have nokia n72 phone. its only working in offline, if i change the profile its showing insert sim card, so pls help me
Hi, kindly switch off the mobile and restart it, once you restart this will ask u phone is currently offlline mode u want to countniue, that time click no, phone will start.
May 31, 2011 | Nokia N72 Cellular Phone
My nokia N72 flashes invalid sim card when switched on
First of all remove the SIM and clean the contacts. Now check the SIM on another phone to confirm, if bad replace, if not the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide
Apr 18, 2011 | Nokia N72 Cellular Phone
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
So much hanging & Battery Problem
Hi Friend,
Kindly follows the below mentioned Steps
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card
Thanks for using Fixya
Regards,
Ayyasam
Jul 01, 2009 | Nokia N72 Cellular Phone
I want to change sim card in my nokia N72
Dear
I think u have some problem with removing back cover of ur phone
To change sim card follow below instruction
1) Turn off your mobile phone (press switch off button on top of the phone)
2) Remove back cover by pressing unlock button on the cover & slide cover upwards gently (please take care you would not force the camera cover)
3) Remove Battery From the phone & u will see ur current sim or sim slot
4) Check instruction & insert your sim
Thanks
Mar 30, 2009 | Nokia N72 Cellular Phone
I have a problem with N72 that when i switch off my cell after some time or at same time when i switching on the cell my balance deducted from my a/c. plz give me solution on 2005anish@gmail.com Thanks...
hello
actually there is a problem with n72.
but anyway....get your sim out of phone and start your phone in offline mode....battery must be fully charged.
reset your phone by going in setting in the menu.
your phone will be restarted none of your data will be lost...
now clean your sim by cotton or cotton cloth using some cleaner.....dry it and insert it.
now start your phoneeeeeeeeeee
if it happens again then contact your service provider and tell them about the problem....(in that case problem is with you sim card........you must then opt for change of sim card..)
thanks..
take care
Mar 02, 2009 | Nokia N72 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
N72 hangs after starting..
does the phone work without the memory card?
Aug 18, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
235 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
