Question about Refrigerators
Fridge too warm - Refrigerators
I had a similar problem several months ago.
1) Top freezer compartment is getting TOO cold. The ice gets so thick, it blocks the channels of cool air from the freezer down to the fridge compartment (hence fridge too warm)
SOLUTION: Turn fridge/freezer off to fully defrost, then turn back on.
NB: This might only be a temporary fix, and you will find in a few months time the same thing happens?
2) In my case, I required a replacement of the "controller" board which fixed the defrosting problem of my freezer compartment.
Good luck.
Posted on Oct 27, 2008
How to fix a warm fridge even after temp is adjusted?
Try cleaning the condense radiator under the fridge. Remove the back lower cover to get to it and make sure the radiator has free air flow thru it, clean it if dirty or clogged
Nov 03, 2015 | Refrigerators
Samsung fridge warm
check the rubber on doors,if they are good.but you need to let check the liquid
Jul 26, 2012 | Samsung Refrigerators
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
270 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
