LG WD 1049 C washing machine leaking from underneath?
Trying to find source of leak in our washing machine, leaking from underneath?
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
futureloginn
  • 734 Answers
SOURCE: leaking washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: oil leak in washing machine
Sounds like the transmission is leaking. These transmission don't need to be full of oil to function. But, if it's leaking a lot, like tablespoons, it should be checked. It's not the end of the line. Just may need a service call if it's a plentiful leak.
Posted on May 05, 2009
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
beltronic205
  • 1467 Answers
SOURCE: Machine is leaking out the front door
Check door boot seal for ripping/ holes in it
Posted on Sep 28, 2009
Washer leaks
There is also a discharge lint filter on the front lower left that has to seal properly. If the water appears only when washing, you can probably eliminate leaking from the water supply side up to the solenoids controlling the water. The most likely source is a leak in the rubber section between the tub and the front door, a leak in the seal between the door and the washer, a leak or overflow in the soap dispenser, or a leak in the discharge side components. You could probably figure out the source if you could view these areas during a cycle, but that would require some disassembly of the cabinet so that you would need to know what you were doing.
Jul 13, 2014 | LG WM2101H Front Load Washer
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
LG Intellowasher 7kg wd-8015c is leaking from underneath
the drum.........which you pop ya washing in.......hangs via 2 spring under the machine lid..........if 1 snaps........you will get more noise......and maybe water leaking via the door seal as the drum wont sit level.........
remove lid then look either side for 2 springs.......
if 1 has snapped its an easy fix.......take you about 1/4 of a hour to do.
cheers
Sep 04, 2017 | Washing Machines
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
Water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
Lg washing machine 1289 fhd
The operating pressure is 4.5 - 116 psi.
Where is the leak?
Feb 08, 2008 | LG WD-1280FHD Front Load Washer
Leaking washing machine
you need to clean above where the drawer goes in, the water jet holes get blocked and spray sidewards. also you can reduce the water pressure at the supply tap to a fast trickle this will avoid jets of water flowing over and forward of the tray.
Jun 22, 2007 | LG WD-1080FD Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
