Question about AMD Gateway MX6428 PC Notebook
How to replace dvd drive in gateqay MX 6428?
I need to replace myfaulty dvddrive in my laptop gateway Mx 6428 because is broken. any idea how to?
  • AMD Master
  • 5,660 Answers
1) Remove ALL power.
Remove the AC adapter (Charger) and Battery.
2) Lay a soft static free cloth on the table you are working on.
Helps prevent scratching the table, and the laptop.
3) Laptop closed, turn it over, lay it upside down on the soft cloth, Battery Compartment AWAY from you.
4) In the middle/right of the laptop is a large odd shaped panel.
Goes from the middle of the laptop to the upper right.
Has 7 screws in it.
This is the Memory Bay Cover.
There are 4 screws along the Top.
2 screws along the Bottom.
These screws are loosened to remove the Memory Bay Cover.
They do Not remove.
HOWEVER, there is a 7th screw. This is the Keyboard screw.
When removed the Keyboard can begin to be removed.
It has to be removed in order to remove the Memory Bay Cover.
This screw is located on the Right side of the Memory Bay Cover.
It is right next to the CURVE.
Loosen it as much as possible. When removing the Memory Bay Cover this screw may fall out. Be AWARE so that the cover is on top of the table, and can catch the screw, if it falls out.
With the Keyboard screw loosened all the way, and the 6 screws which hold the Memory Bay Cover in place, go to the Top of the Memory bay Cover.
There is a Thumb Notch at the Top/Left side of the cover. Use your thumb to lift up on the cover.
NOTE*
There are plastic tabs formed out of the cover, and they are on the opposite side of the Thumb Notch.
Raise the cover to a tilting position, and lift the cover away from the laptop.
Otherwise you could break these plastic tabs off.
5) At this point you NEED to follow Anti-Static Precautions.
You are looking at the copper Cooling Tube, Heatsink, and Fan Assembly.
The Processor is right there, under the Top Cooling Tube's aluminum metal plate.
{The graphics chipset is under the small aluminum metal plate, at the end of the Bottom Cooling Tube }
A Processor is the most susceptible hardware component, to Static shock.
It would be best to use a plastic screwdriver, or wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Average cost of an ESD wrist strap is around $3 to $6)
IF nothing else, KEEP your fingers away from the cooling system.
Make SURE the metal Philips screwdriver you are using has no Static.
In the Memory Bay Compartment to the immediate Right, of the bottom Cooling Tube's metal plate, is the DVD drive screw.
Look at the copper Cooling Tube on the bottom. Look at the small aluminum metal plate on the end. Come straight over to the right.
There's the screw hole you removed the screw from, for the Memory Bay Cover, and above it is the DVD drive screw.
Remove this screw.
(Loosen all the way, CAREFULLY turn the laptop over, and let the screw fall to the table. Do NOT lose it)
Press the tray button on the DVD drive. This makes the tray pop out a little bit. Gently pull the tray until it is all the way out, then pull the DVD drive out of the laptop.
For additional questions please post in a Comment.
Also, here is a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to the top heading that starts with Gateway 400. (400 in blue)
Drop down to the second line, and scroll across to MX6400.
Click on MX6400.
{The Gateway MX6428 is part of the Gateway MX6400 series of Notebook PC's }
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (MX6400), it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 11.
Regards,
joecoolvette
Posted on Feb 18, 2012
Hi,uhm,,i have a asus p5vdc-mx motherboard..it had already a DVD-ROM, but when the dvd-rom was broken, i bought another one.,here is the problem, after i connected the new DVD-ROM,Same way as with the old...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 06, 2011 | ASUS P5VDC-MX Motherboard
I need to reset from factory my laptop gateway MX 8737
Your Notebook should have come with a Software Recovery DVD. Just put that into the DVD Drive and reinstall or reformat Windows. Warning: Bringing your Notebook back to factory settings will erase all the content on your HDD. Back it up if you want to save anything.
Jan 02, 2011 | Gateway MX8734 Notebook
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
There is a disk in the drive but it keeps asking me to insert a disk when i try to play it
I cant understand what device (laptop/desktop)you are using.
So i will try to present, desktop or the laptop also.
Click on the link
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
And clink on RUN NOW from right side box
It will fix your problem.
It could be a problem with the lens, you shouldtry cleaning the lens, it's already gone bad there is no harm in trying. If you take a little risk can solve.Follow the instruction: Don't panic it's very simply.
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. now you can fit to your pc
  4. If it does the same problemplease change the cd/dvd rw because the lance has defected.
  5. HOW TO REPLACE CD ROM e.g. follow link=http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=&cc=us&lang=&product=242024
For Laptop http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Hope it will help you.
Dec 28, 2010 | Gateway (5500652) (  5500652)...
My motherboard cd of asus m2n mx se series nvidia is broken so
You can call Asus and buy a new CD at 1-812-282-2787 US.
Or you can download the drivers directly from Asus and burn the drivers to CD/DVD-ROM disk. Link to Asus motherboard M2M-MX SE;
http://www.asus.com/Search.aspx?SearchKey=m2n-mx%20se
Cheers'
Mike
Mar 26, 2010 | ASUS M2N-MX SE Motherboard
Replacement video card gateway mx 3210 notebook
Unfortunately you have a lap top and the Video card is built into the motherboard. You have two choices. 1. Send the unit to Gateway and have the motherboard replaced, expensive and time consuming. 2, Replace the laptop with a new one, expensive but most likely a better solution.
Oct 15, 2009 | Gateway MX3210 Notebook
Disc consistency, dvd player not recognizing discs
Your cd/dvd drive is most likely failed. Possible controller problem but most likely dvd drive. Replacement is fairly straight forward but replacement may be a bit costly. I would search for sources for used / refurbished drives; contact me if I can assist you further.
Dec 24, 2008 | Gateway MX6448 Notebook
I need to replace the cd drive on a 2006 Gateway MX 6956 laptop. Can you please tell me how to go about it?
it's really simple..turn over the unit..find the cd drive..trace your finger about 1/3 of the way along the middle on bottom..you should see a single screw.remove it..then on face of cd, should be a release button..press it..should slide right out.
Nov 21, 2008 | Computers & Internet
My laptop now can't play DVD but plays cds, mp3, vcd
go to device manager and scan for new hardware changes or try to update the drivers for the device..
if it doesnt work try to reinstall the power dvd 6 or update it with a new version...btw poer dvd 8 are available now
thankyou
Oct 30, 2008 | CyberLink SW- DVD Software Power DVD...
Gateway MX 6440 laptop
You may be right about the mboard but also try changing the processor or taking out the processor and try powering on withou the processor. If its the mboard then it could have been because of a power surge and thus the mboards needs to be replaced. let me know how you go. thanks
regards
Dec 12, 2007 | Computers & Internet
AMD Gateway MX6428 PC Notebook Logo
174 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
