Question about Hitachi 51SWX20B 51" Rear Projection Television
Factory Reset Hitachi 51swx20b
Do not have original remote and need to reset aspect ratio of hitachi 51swx20b is there a way I can factory reset it
  • 308 Answers
SOURCE: Hitachi skips over commercials & flickers
If by saying the "aspect ratio changes" you mean the picture shrinks from top and bottom, I would suspect an intermittent short inside one of your picture tubes. The commercial skip function is not causing a problem here. It is the rapid change from dark to light that I believe is putting an extra strain on a weak or defective picture tube.
Posted on Jan 18, 2007
  • 192 Answers
SOURCE: Hitachi Ultravision LCD Rear Projection
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on Jun 24, 2007
  • 5 Answers
SOURCE: hitachi cp-x430?
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Posted on Jan 06, 2008
Drummernick
  • 440 Answers
SOURCE: Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
Posted on Feb 03, 2008
  • 375 Answers
SOURCE: Red Tint on Hitachi 51F510
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
Posted on Apr 13, 2008
How can I do a factory reset on a Hitachi clu-5729TSI
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 07, 2015 | Hitachi Televison & Video
How to change the aspect without the remote?
There might be a little button but unless you have the factory remote get a Harmony 650 universal remote. It can handle everything the factory remote can do.
May 20, 2014 | Hitachi 51F500 51" Rear Projection...
My hitachi tv 36ux01s is stuck on pip. need to reset factory settings
Enter factory mode, and do a factory settings. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Hitachi 36UX01S 36" TV
How do you change pixel? i have dish network. HD channel is perfect but when i see regular channel, picture is cut off from the bottom and top. its very irritating when you see game. i tried changing the...
You will want to keep your aspect ratio on 16x9. On your DISH Network remote press the format button on your remote it will have an asterisk (*) on it. Also, try the page up and page down buttons right of the volume. If that fails take the factory remote and try the format button there as well.
Daniel Busa
DISH Network
Customer Service
Feb 25, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I need to make the picture smaller to fit the screen. do not have original remote.
Tries this website for a new remote 1-800-Remotes Factory original for new remote or tries the manual controls on the tv for functions to ajust the screeen sizes.
Oct 31, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Aspect Ratio or Input Issue
Not sure but you might be confusing your aspect selection on your DVR with aspect selections on the tv itself. Make sure you use your hitachi remote & check all available aspect ratios. Find one that suits u best
Apr 06, 2009 | Hitachi 51F500 51" Rear Projection...
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Jan 18, 2007 | Hitachi 43FDX01B TV
Open Questions:
See all Hitachi 51SWX20B 51" Rear Projection Television Questions
Hitachi 51SWX20B 51" Rear Projection Television Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
