F-35-4 this code is displayed the machine is not working
How i can solve this problem
    Problem Solver:
  • 14 Answers
If this unit is Konica your problem is under fusing problem. Clean first fusing unit and check the temperature sensor and thermostat could be dirty. reset under 25 mode "hold 2&5 while turn power on, select SW adjust 3-2-0 up to 3-7 set all to 0 then back, try off and on power. if don't work check 3 component 1. lamp. 2. temp sensor 3. thermostat if broken or busted replace it. but still use reset procedure.
Posted on Feb 20, 2012
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
Tip
Maytag F-35 (suds) error code resolved
Maytag Washer F-35 error code ( SUDS) >> Look for a faulty Pressure switch or bad pressure hose.... Problem solved !
on Aug 04, 2010 | Washing Machines
I have a gwl15 Fisher Paykel Smart Drive and it will not get past the rinse cycle, water will not drain out! I found the diagnostic mode sheet and the number I come up with is none of the fault...
Hi - it would seem the washer pump may actually be blocked for some reason... If you had followed the method as per the diagnostics then if you reckon you got 35 then its a communications error beween the console & display. Furthermore you would be able to mannually start the pump in diagnostic mode to see if its working fine.. But under normal cond..... the machine would come up with a pump error & code 37 - so perhaps it is ok.
Remedy - check the harness wire connections between the display & the controller unit is good - clean - otherwise replace the display unit to correct.
On the error codes - there is a Code 35 - just that its not available to the public - it was only ever issued on a DVD sent to the service agents - have never actually seen it on the secure service site.
See how you go....
Jul 11, 2011 | Fisher Paykel EcoSmart GWL15
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Trouble code F 35 about 5 minutes into wash cycle. Unit stops dead.Will not respond to hitting cancel twicw as recommended in owners manual. Will work again if I unplug washer for 15 minutes and plug it...
F35 = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Nov 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Error code F35
f 35 is not in my info book . if you remove front panel 3 screws at bottom . inside there is a tec sheet with the fault codes. i would ck the clean out for the pump . it is right in front when panel is off . this may solve your prob .. .. mm
Nov 22, 2009 | Kenmore Elite HE5t Washer
Whirlpool Duet washer Displays F 35 code and stops
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a code error in toshiba e-studio35 .the code is 09-5272512 please if anyone has a service manual to tell me how to solve it
Don't think this is the error code....this is the phone # to call if you get the error code...
The real code should strt with a c or an e and be displayed on the screen somewhere.
Jun 10, 2009 | Toshiba e-Studio 35 Copier
F 35 light on Kenmore Washing Machine
am sorry but F-35 is not in the record.
If this is a different F# please e-mail us back
I will be more then happy to assist you
"Was this helpful?"
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
27 people viewed this question
jasbo
jasbo
