Question about Garden
Engine power fluctuation - Garden
I'm assuming that you are referring to your lawn mower engine fluctuating up and down (cycling) instead of running at a steady, constant speed. Fluctuations are about every one to two seconds?
My old lawn mower did this a few years back. I found that it was a clogged fuel filter or fuel line. Once I replaced the fuel filter and cleaned all the fuel lines the problem was gone. Bad (old) gas can sometimes be the culprit as well. If you leave gas in the tank during winter months when the mower is not being used its a good idea to add some fuel stabilizer to the gas tank to keep the fuel from thickening (jelling). Also, check the fuel tank for dirt/grass etc. If its a metal tank, check the inside for rust.
Good Luck!
Posted on Feb 18, 2012
Odometer fluctuating causing engine to stall
the odometer is what reads the mileage covered
I suggest that what is fluctuating is the tachometer and as it is powered from the ECM or coils ( reads a power impulse) that if it is causing the motor to be erratic then it could be a wire or a faulty tacho unit.
Aug 08, 2015 | Cars & Trucks
How do I fix a p1399?
Tech notes
Adjusting the valves will usually fix this problem.
When is the code detected?
The control module monitors the crankshaft speed and has detected a misfire condition
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/loss of power
- Hard start
- Engine hesitation
P1399 Honda Description
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Crankshaft Position (CKP) sensor signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
- Valve clearance out of range
Jul 16, 2015 | 2004 Honda Odyssey
Fluctuating idling when hot
hi. turning on the air conditioning does normally take between 7to10 brake horse
power from your engine ...............
Mar 03, 2014 | Toyota Avanza Cars & Trucks
Engine running up and down at higher throttle, sometimes low throttle
clean the carburetor and replace the needle and seat.
Nov 19, 2017 | Craftsman Garden
Fuel system problems
I believe the IO-550 has an electric fuel boost pump that is activated by throttle position. It might be that the micro-switch that activates the pump has been improperly set, causing the pump to turn on & off at cruise settings. The pump is there to make sure of sufficient fuel delivery at high power.
Bob
Jun 14, 2013 | Cessna 185 Skywagon Owner Manual
1994 Subaru Legacy 250T engine cuts out
It could many things, please go for a scanner test
Mar 11, 2013 | Cars & Trucks
Should the oil pressure gauge fluctuate with speed
The oil pressure guage will fluctuate with engine RPM. At idle it should be approximately 20 lbs./sq.in, at high revs about 50-60 lbs./sq.in. Hope this helps any concerns you may have. Good luck!
Jun 05, 2010 | 2004 Chevrolet Express
Take off power fluctuation.
Sounds like you have a problem with your turbo or your turbo waste gate Check your boost output from your turbo guage. That enggine under heavy load should produce between 20 and 25 lbs of boost.
Jan 26, 2010 | 1999 Ford Super Duty F 450
Fluctuating engine temp a/c sends out cold air intermittently
Here's the thing. The ECU will shut down AC if the engine temperature is too hot. If the coolant temperature sensor is malfunctioning (lying to the ECU) telling it that the temperature is hotter than it actually is, the computer will turn the AC OFF.
Sep 11, 2009 | Hyundai Motor 2003 Elantra
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
