check and see if its getting hotter than it use to...If so it might need to be cleaned or the fan replaced...the only cheap solution that i could think of is like I had a friend do when he had this prob...Get a usb cooling pad for it...places like compusa or other computer dealers norm carry one..search online and look for lap top colling and you should pull some good ideas...the other prob could be a virus or spyware...they can over load the system and make it just shut down to save its self...but from what i read it might be overheating..
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Feb 26, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try to replace the faulty cpu fan replace the faulty main board try to remove virus and spywares with updaed antivirus and spyware remover use the laptop in minimum temperature and humidity
Mine does the same thing. But when I run it with an external keyboard, it doesn't freeze. I have replaced the keyboard, the hard drive and the power jack (burned to toast), to no avail.
Comments:
Feb 18, 2007
- Also, I have NO extra programs running, not even the Acer Ferrari built-in programs. My Ferrari runs much cooler since I replaced the factory installed Windows XP.
Was this helpful?
Yes
No
Solution #4
posted on Jan 21, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem. I think it is a bios issue, regarding powered mode and travel mode.
I need to open my sony vaio model pcg-8f1l laptop. I need to repair the power input connector. How...
(More)
I need to open my sony vaio model pcg-8f1l laptop. I need to repair the power input connector. How do I open?
my packard bell (easynote f0445) has problems with the monitor. the monitor appears to have lines in...
(More)
my packard bell (easynote f0445) has problems with the monitor. the monitor appears to have lines in it and sometimes it just fades to bright white (along the corners) that progresses to the center. when the screen totally disappears, the edges become white, the center just black or dark gray (some times with small black dots visible). when i press the edge of the monitor it sometimes returns to normal but problem comes back when i release it. i tried closing and opening the monitor but that didn't work either. restarting the computer also didn't work. the problem happened after i dropped my bag (laptop inside with a padded case) from less than a half foot. i didn't expect the damage could be this bad. can my computers still be fixed? i've had it for 2 years already and i think it's not in the market anymore.
Hello. I have a Acer Extensa 5620Z and I am having issues having a conection to a projector. If i re...
(More)
Hello. I have a Acer Extensa 5620Z and I am having issues having a conection to a projector. If i re boot it shows windows booting but thats all.
I have an aspire 1711 SMI, who doesn't work properly since several months. The display was starting...
(More)
I have an aspire 1711 SMI, who doesn't work properly since several months. The display was starting to fall down and now there's no diplay at all, completely black. Now, when I start the notebook, the Power button and the led on the display are flashing green to orange together. Could you tell me a diagnostic and what kind of piece to change ? I saw that it's often a problem with the backlight lamp or the screen inverter. I'm a computer Technician and really love this computer and I really want to repair it. Thanks for all an sorry for my poor English (I'm french)
