Machine will not drain - Washing Machines
    Master:
  • 431 Answers
Check the pump is not blocked. usual suspects are small coins and hair grips
Posted on Feb 18, 2012
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Unable to locate the drain so that we can drain the machine. Can you advise where the drain olug is situated
Washing machines usually do not have drain plugs. Take the drain pipe and lie it on floor and let it drain into a flat container, this is the only way I know of draining a machine.
Mar 06, 2011 | Washing Machines
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine keeps draining on the rinse cycle.
your drain hose is either stuck to far down in the drain pipe or your drain hose is sealed to the point it has no way air can enter the drain pipe which creates a siphining issue. your drain hose has to have a air gap so the siphing can not occur. the end of your drain hose should be no lower than 34 inches from the floor draped into the drain pipe with a way air can enter at that piont.
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fisher Paykel Wash Machine GWL11US
hot drain pump? suggests that the pump is not being lubricated properly...
May 27, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
