Question about Samsung SCH-u740 Cellular Phone
My phone won't charge. I try to plug it into the charger, nothing happens. Any suggestings ? Thanks
  • 1 more comment
  • boomx2 Oct 31, 2008
    im having that problem right now. it worked fine last night but for some reason its not working. i already had to buy a new charger for it and that was only a few months ago. now my phone wont charge. i dont think its a charger problem but it could be...
  • xalix Dec 08, 2008
    i just got my phone last night and im already having that problem & its not the charger bc i took my cousins & its still not working
  • Anonymous Dec 24, 2008
    my phone wouldnt charge so i went to the verizon store, and the lady said i needed a new charger. So i got a new one, this was about 3 months ago maybe? and now its doing the same thing with not charging again!! UGHH.
I had your problem. I thought my phone was defective, it turned out all i needed was a new charger. Try that.
Posted on Oct 31, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
My Nokia E71 won't turn on or charge up. What can I do?
please check ur charger's hole (phone or charger). and - may touching:) thats y ur phone switching off:)
Jul 17, 2011 | Cell Phones
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
Dead Phone?
The D-wade sidekick 3 uses a charging port. You should see a little round plug in on one end of the phone. you will need to get a charger from eBay. They are about 3-5 dollars shipped.
The usb cable is only used for transferring data, no charge capability exists for it
May 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Samsung SCH-u740 Cellular Phone Logo
80 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
