Question about Samsung HCL4715W 47" Rear Projection Television
Phillips Magnavox rear projection T.V. 47"screen
SOURCE: Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Posted on Jun 19, 2008
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
SOURCE: Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Posted on Sep 30, 2008
SOURCE: Samsung 47" HD Projection TV with color distortion
COLOR CONVERGENCE IN THE MENU
Posted on May 15, 2009
SOURCE: I have a 47
You have a vertical sweep circuit problem. There is an IC chip that controls this which may have failed or the capacitor for the IC has failed or both. The third possibility is that a fuse on the power board that supplies voltage to the convergence ICs has blown.The first step would be to check voltages to the convergence ICs. If that is okay then the vertical sweep circuit would be next, These are simple repairs but require some tedious soldering and familiarity with electronics.
Posted on Dec 04, 2009
Oct 23, 2012 | Philips Televison & Video
Jun 30, 2011 | Televison & Video
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Jul 07, 2008 | Televison & Video
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Nov 09, 2007 | Philips Magnavox 9P6034C 60" Rear...
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
66 people viewed this question
