Question about ViewSonic Computers & Internet
ViewSonic G90f power-on confusion
I don't have much experience with desktop monitors (since I was younger), and I recently plugged in a ViewSonic G90f CRT into a computer I recently built. Whenever I turn on the computer and then press the power button on the monitor, it turns on, says OFF MODE IN 5 SECONDS, and turns off. I don't really know what to do to make the monitor do its job. It's probably obvious, but as I said before, I don't have much experience with these. Thanks in advance to whoever finds a solution!
    New Friend:
  • 97 Answers
Crt monitor uses.vga port do you any laptops you can plug in and see if monitor actually works ... recently built pc so does that mean you shoved in another graphics card if so does your graphics card also have vga port, if it does try that
Posted on May 30, 2017
  • 114 Answers
SOURCE: Switching to "off mode"
Sounds like your video adapter settings have been wedged. If you are running Windows XP Service Pack 2, you can use the following steps. 1) Boot the laptop into safe mode. Boot into safe mode with networking support if possible. This can be done by tapping the F8 key as the computer first turns on. 2) Once you are at the Desktop, right click on My Computer and select Manage. 3) In the window that appears, select Device Manager from the menu on the left. 4) Find Display Adapters on the right and click the plus sign. This will list the video adapter that you have. NOTE: WRITE this down EXACTLY. You may need to go and get drivers for this. Seeing this is an older model, I doubt you'll need it, but better to be safe then sorry. 5) Go to your manufacturers support web site and download these drivers. You may not need them, but better to be safe then sorry. NOTE: Skip step 5 if you did not boot with network support or cannot get to the Internet. This can be done from normal mode. 6) Right click on the display adpater and choose un-install. Hit OK on the window that appears and reboot the machine when the process is done. 7) The machine will take longer than usual to boot, as Windows XP is re-discovering the video adapter and resetting everything to the defaults. When it is done booting, the screen may look weird since the settings are now the defaults. You can the set them to what you want by right clicking on the desktop and selecting properties. Then go to the settings tab. 8) IF it did not re-discover the video adapter (this can be confirmed through the device manager), then go ahead and install the drivers. Windows Update will most likely also have the drivers.
Posted on Oct 16, 2006
SOURCE: ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Posted on Jul 26, 2007
  • 1114 Answers
SOURCE: Analog Power Saving Mode
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Posted on Jul 30, 2007
  • 1601 Answers
SOURCE: have no sound
your monitor has no speakers for sound.
Here are the specs:
Posted on Dec 01, 2007
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
I just recently acquired a Viewsonic VA521 LCD monitor from a friend who experience a power surge/outage. When hooked up and powered on, it shows the desktop for a split second, then seemingly goes black,...
It is possible that you can adjust your refresh rate. You may need another monitor to set the rate.
You may also be able to boot into safe mode. Try pressing F8 as soon as the system completes the POST (if you can see it). From safe mode, you can adjust the rate.
Can you get anything from the monitor without connecting to a computer? You should try to reset the monitor to its default settings.
May 20, 2010 | ViewSonic VA521 (Black, Silver) 15" LCD...
Viewsonic n2750w turns off half a sec after power on, still sound
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Is ViewSonic Monitor worth fixing?
Probably not, but it will be a good electronics repair learning experience.
Look inside to see if it has any bad caps first. Model??
Feb 12, 2010 | Computers & Internet
Can't see full desktop
Change your screen resolution in System Preferences >> Displays. Experiment until you find what is the correct setting.
Aug 01, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic
If the power supply is not wqrking then it is the invertor unit that has dies.
Replace the monitor is the best advice- If it that recent out of warranty may be worth contacting 'viewsonic to see if they will discount you one.
Jul 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
59 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
