Question about Cricut Expression Cutting Machine
I need a manual for a cricut expression
I am looking for a manual for a Provo Craft Cricut Expression Cutting Machine.
  • 6 more comments
  • Anonymous Mar 11, 2014
    time date change on nortel network phone
    how to locate the pvc valve
    where is located back up light switch honda civic 2009 manual
    My yamaha pw80 is reving really high unless i have the choke on I have cleaned the carb and jets and tried moving the needle in the carb but no luck what could it be?
    My Samsung Convoy has quit vibrating - I know it is set correctly and i have powered it off and back on - no luck- suggestions?
    can get a manual that I can hold
    how do i replace and refit a water pump drive belt on a hyundai matix?
    Oily spots on washing
    Problem Solver:
  • 6 Answers
Www.manualsonline.com/
Posted on Feb 18, 2012
4 Suggested Answers
  • 7 Answers
SOURCE: My LCD on my cricut
after doing some research i found a lot of problems with the machines purchased this xmas exp the colored ones the best thing is to contact cricuit and see if they will replace them
Posted on Jan 11, 2011
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
  • 313 Answers
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
Posted on Jul 25, 2010
Where I can buy Cricut Expression Roller Bar Endless belt?
I would measure the belt total length and look it up on the web.
Aug 04, 2015 | Cricut Expression Cutting Machine
How can I get a new Encoder board V2Encoder for a Cricut Expression?
You may be able to get a replacement circuit board from the source where you purchased your Cricut Expression. More likely, It will require an inquiry to Provo Craft to determine availability and source.
Feb 02, 2015 | Provo Craft Cricut Expression Personal...
How do I get a spare handle for a Cricut Expression Cutting Machine from Provo Craft
Check with a craft supply store which handles Provo Craft products.
Jan 29, 2015 | Tools & Hardware - Others
My Cricut Expression is not working. When i pressed the cut point on the screen all it did was a loading screen and would not cut. What should i do?
fruchey10 you have not given me enough info to help you but if you contact me I will try to work out a solution to your problem. exactly what are you doing ie do you have images loaded onto the image queue. contact me via my website OhSoManyCrafts
Feb 02, 2014 | Cricut Expression Cutting Machine
My cricut wont turn on
Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
Jan 26, 2014 | Cricut Expression Cutting Machine
Why does my paper move out of place when the cricut expression is cutting? Is somethhing wrong with the roller bar?
I would just use a new cutting mat if the mat your using isn't sticky enough your paper will move.
Mar 25, 2012 | Cricut Expression Cutting Machine
Is there a replacement strip for under the slide
http://www.cricut.com/shop/#0/1/349/3/Cricut/Cricut%20Expression%20Machine%20Replacement%20User%20Manual
This has a list of all the replacement parts on the left side.
Mar 09, 2011 | Cricut Expression Cutting Machine
My LCD on my cricut expression machine will not work
Jan 11, 2011 | Cricut Expression Cutting Machine
Cricut Expression Cutting Machine Logo
539 people viewed this question
Top Cricut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
