Question about Kodak Professional 8500 Thermal Printer
Printer will not use cyan
Printer will make two passes using yellow and magenta and will not complete the print with cyan (or blue). After two passes, I get error (red) indicator and media light goes off. Tried printing images and test pages and they're both doing the same thing. Need help, I've wasted 8-9 papers. Thx.
  • Anonymous Dec 27, 2007
    pls help us i too have the same problem
This sort of thing is usually due to dust/dirt on the sensor that detects the gaps in the dye-sub film. Half of the sensor pair is in cover that flips up to replace the ribbon, the other half is under the plastic bar. I clean them with a dry Q-tip or blow them off with canned air.
Posted on Dec 22, 2008
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Does not print all colors on some passes
If some colors are printing but other colors are not printing this usually indicates a problem with the printer color supply (ink, film or toner exhausted), a problem with the printer (stuck ink nozzle, dye film not advancing, toner drum clogged or jammed), or a problem with the printer drivers used on the computer. Refer to the documentation that came with your printer and printer software for assistance. and even then if u want our technician support contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Canon iPF700 InkJet Printer
Kodak Professional 8500 Thermal Printer Logo
178 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
