Question about Garden
Repaired Husqvarna 41 chainsaw won't start.
The on/off switch on my Husqvarna 41 chainsaw stopped working (didn't kill the running engine). Tired of pulling the choke, I replaced the switch, and in the process noticed a break in the two strand wiring harness. I replaced the wiring harness, and now the saw won't start. I have found complete electrical continuity between the base of the plug and both poles (and the plug end of the plug wire) of the ignition module and both poles of the switch (whether on or off), but no continuity between the top of the plug and anything else. How does the off switch on this saw work? Is it supposed to establish or kill continuity?. Suggestions?
  • Anonymous Dec 05, 2008
    Check if there is continuty between the wire coming out of the coil, not the plug wire the small one, and ground, metal partof the coil. I just ordered a coil because of this. The coil seemed to have some spark even tho this condition existed. Richard
    Problem: There was some spark at the plug. The plug got wet, fuel present. Would not run. Checked the coil there was continuity between the small wire coming out of the coil and the metal bolt down of the coil. Ordered a new coil.
  • 211 Answers
The off switch of the chainsaw has to establish the continuity to kill the running engine.First check the switch with a measure apparat.Then check the continuity of the two wiring harness,sepparately.One wire is atached to the ignition module with a screw and goes to the off position of the switch.The other one towards the on position of the switch.Check the spring!
regards savumihai71
Posted on Dec 03, 2008
  • Savu Mihai Dec 03, 2008
    I forgot to tell you that the other one starts from the ignition module
    wishes savumihai71
  • francisco torres
    francisco torres Oct 26, 2013
    my husqvanar when i stars runs for two minutes could some ,one help me?
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
Husqvarna 445 start/stop switch won't stay in choke
remove the top cover and see if the pins are broken from the sides of the lever
Sep 05, 2012 | Husqvarna Garden
I have a Husqvarna 55 and it quit running and now won't start. I pulled the plug and put a drill on the flywheel nut (electric start- tired of cranking)and spun the motor. At low RPM there is no...
I would say yes the coil is bad, they do work off speed of rotation, however there is a limit to how fast you can phisicaly crank the engine by hand, the coil is part number 544018401, check out the web for sellers of this component.
Sep 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No spark on model 41
hi there tschake
pull kire from ignition unit , recheck for spark if spark there again faulty kill wire or switch, but if still no spark faulty coil indictated , replace coil and set air gap to 0.010 thou
get here tpgether and let her rip
cherrs hope it helps
Sep 15, 2011 | Husqvarna Garden
I have a husqvarna 450 that won't stay running and has oil coming out the excaust
It sounds well flooded, remove the spark plug, with the kill switch to off, crank the engine five or six times to evacuate any excess fuel in the cylinder, leave the machine for an hour or so, re fit the plug and attempt starting with no choke.
May 30, 2011 | Husqvarna 450 e-series 18" Chain Saw
Kill switch will not stop motor
Check and make sure the wires are plugged into switch.If that don,t work it has a bad switch.
Nov 30, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a husqvarna 36 chainsaw that starts and runs just fine. However, the stop switch doesnt seem to work. I push the switch to stop and the saw continues to run. The only way to kill it is to use the...
Yeah,your switch has gone bad,and using the choke isn't how you want to kill it for too long.Fouled Plugs.Here's a link to the service manual pdf if you want to do it yourself. Shouldn't be too hard.
Please rate my post?
Aug 13, 2010 | Husqvarna Garden
Stop switch
one end of the blue wire goes to the ignition coil and the other end goes to the stop switch.
Feb 22, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
1,875 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
