Question about Elna Sewing Machines
What kind of bobbin goes in an elna super type 62c?
    Scholar:
    New Friend:
  • 102 Answers
Elna Tavaro SA swiss made machines all take a 720100 bobbin, looks like this
what kind of bobbin goes in an elna super type 62c - 49adda86-f616-419d-9902-4ff8138a1e49.jpg
Flat on the bottom and 7 holes on top and slightly dished. Dont use anything else. You can buy them aftermarket from www.sewingpartsonline.com or any Elna dealer and I have seen them in my local Spotlight in Australia.
Posted on May 29, 2014
  • 5 Answers
SOURCE: bobbin casing for elna 8000
There is one small metal piece 3/4 inch long and shaped like the letter "T" that fits under the right hand needle plate snap one screw. Attach to underneath square nut and can be seen sticking out from the top holding the bobbincase in place after the top plate is replaced and everything is back together. If this is not it, a picture would help as I have repair 100's of Elna 5000 to 9000's.
SewTech
Posted on Apr 21, 2008
SOURCE: 1972 Elna model 62C
i guess i thought i could get some help with starting the dismantling. but of course, except for chit chat, if i don't pay, my affiliation with this site is useless. my machine is 36 years old. i found sewusa that had drawings, but only limited number. yes, when i go at it cold, i will post how i removed the old gear, so someone else can get this help. cheers
Posted on Nov 04, 2008
SOURCE: needle centering wheel is stuck tight and cannot
On these machines, the shaft UNDER the centering wheel fits into a bushing, and this is what normally rotates. The wheel is fixed to the shaft. Penetrating oil needs to be placed UNDER the centering wheel but above the bushing. We solved this problem on two machines by saturating dental floss (the kind used to clean braces) with penetrating oil. Insert the floss UNDER the plastic wheel around the shaft, with the two ends sticking out the slot for the centering wheel. Then cycle the floss in and out of the area around the shaft. Let it soak and repeat. It takes some time, but it worked, and did not require disassembly of the machine. Greased Lightning also was used. Kithen grippers help with rotating the wheel.
Posted on Sep 25, 2009
SOURCE: cannot remember how to thread bobbin elna
i solved the problem after i had a closer look at the top of machine
Posted on Feb 21, 2010
SOURCE: MANUAL for ELNA 62C ELNASUPER INDUSTRIAL SEWING/STITCHING MACHINE
i want learn gents shirts and phants how to learn i
Posted on Jun 11, 2010
Elna 62c sewing machine feed dogs and bobbin case
It is likely the bobbin case isn't installed properly.
Apr 09, 2018 | Elna Sewing Machines
Elna 6003 squealing.
I personally prefer the metal bobbins, as per the vibration & the lack of smoothness have you checked the spindle behind the bobbin is clogged with cotton thread? Plus check the jaws that move the material under the plate for fabric/cotton/fluff deposits as this can have an effect on its running, or as a last resort make sure the belt is not coming apart, this is about as far as my knowledge base goes on this topic, maybe it would be best to have it services by a professional...
I do hope I have been of some use/help....
Feb 22, 2018 | Elna Sewing Machines
Where can i buy bobbin case for elna sewing machine
from a service agent for elna
from e-bay--- in the search or want to buy section , type in bobbins for elna sewing machine
from elna on line spares department.
Sep 03, 2015 | Elna Sewing Machines
Can you find a user manual for an elna supermatic V/NV/62?
Lots of places have them
Google
Elna 62C Sewing machine manual
Jul 18, 2014 | Elna Sewing Machines
Bobbin case Elna 62c
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
Dec 29, 2013 | Elna Sewing Machines
The bobbin extractor is broken off the Elna that I pruchased on Ebay. Can these be replaced? This is an old Elna 62 Super.
here are some site that have elna parts
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
brubakerssewing.com
Sep 12, 2011 | Elna Sewing Machines
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I am looking for an Elna 62C manual
try these sites
sew usa
sewing manuals.com
ebay
Jul 22, 2010 | Elna Sewing Machines
Sewing Machines Logo
114 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
