Question about Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier
3500 watt pure sin wave inverter
Power jack inverter from tiawan bought in march deliverd in june was supposed to be 3500 watt with 50 amp charger built in it runs on main power when main power is cut it changes to inverter mode ie 230 volts from 12 volt battry when power back on changers back to mains power and puts battry charger mode on till 90% battry chargedhave been trying to get power jack to send parts to fix they sent replacement and it did not funcion properly 1 st one worked only on inverter mode 2 nd one worked only on mains mode at no time did battry charger mode come on we changed a board they asked us to remove and refit we put either board in the other inverter and both inverters worked as when first installed please can you help my name is steven hayes you have my email address or my mobile number is 07737388228 i would like to get working properly as not cheap
  • pblaisdon May 02, 2009
    power jack 3500 pure sine inverter/charger.lights come on and that's all.Company doesn't want to know.
This engineer, Mandfred has a "Nightmare Story" for you ...
http://ludens.cl/Electron/chinverter/chinverter.html
If you have the exact same model, Power Jack 3500, then I seriously doubt you will ever get your inverter working long term without making all/most of the modifications that he made.
Posted on Dec 30, 2009
  • 615 Answers
Did you check and see if they sent the correct one? they do have 50-60 cycle or 50 only make suer you have the correct cycle first.
Posted on Sep 08, 2009
  • shaun zweifellow Feb 16, 2011
    OMG i wish i read the write up above before i brought one... you can search
    "Smoking inverter" on youtube to see my one!
    DONT BUY FROM POWERJACK!
Tassimo coffee machine
Most power inverters require the vehicle to being running to operate, and make sure it's the correct wattage, if it's a small watt inverter it doesn't have enough power, as a coffee machine is considered higher wattage, hope that answers your question ?
Feb 21, 2015 | Magnum MM1524AE : 1500 Watt, 24V Inverter...
I have a 24 volt 5000 watt pure sine wave inverter that keeps tripping. It has 28.6 volts going in from the battery and 115 volts going out at 8 to 12 amps any suggestions.
It sounds to me that you have a load that draws too much from time to time. If the inverter will run without a load without a problem, try adding loads one at a time until it starts to trip off. That should give you an idea as to what the problem is. It could be that there is a problem internal to the inverter that causes it to trip prematurely..
Jul 11, 2014 | Inverter Aims Pure Sine Wave Power...
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
I have a 1250 watts inverter and i wanted to know if i can connect it to my 2003 ford explorer without connecting it straight to the battery
Let us look at the math. 1250 watts at 120 volts is w=va Watts equals volts times amps. Or in this case 1250 divided by 120 volts = 10.41 amps. But what is the 12 volt side capable of drawing. 1250 watts divided by 12 volts. 104.10 amps. This is more than what the average cigarette lighter or power port can provide. So, yes you need to connect directly to the battery, you can use a relay rated for 100 A in between the inverter and battery to control the power to the inverter. I would use a good #2 copper welding cable for the power leads. Now, if you are not planning on using the whole 1250 watts, then you can use a #4 welding cable (it is very flexible) for power leads.
JOE
Jan 21, 2011 | Inverter Aims Pure Sine Wave Power...
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Inverter shut off and turn back on..
Sounds like one of two things are happening:
1. Microwave is drawing too much current, causing internal voltage monitoring circuitry in inveter to go into protection mode.
or
2. RFI from microwave is somehow being few into inverter causing similar circumstance.
Feb 27, 2009 | Inverter Pure Sine Wave 1500w Inverter
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Inverter problem
If you got the store bought APC 350 UPS, you most likely overloaded them, and killed them beyound repair.
People should never buy a 350VA. They are way to small for power supplies most of us now have. you need to start out to 1000VA plus you need to do the math to figure out how big of a UPS you actually need in the show room.
What am I talking about? What is the significant, or the math of what I am saying here. 115V x 1 amps = 115VA x .778 power factor = 89.47 watts Start up 50 watts = 39.47 watts
115V x 2 amps = 230VA x .778 power factor = 178.94 watts Start up 50 watts = 128.94 watts
115V x 3 amps = 345VA x .778 power factor = 268.41 watts Start up 50 watts = 218.41 watts
115V x 4 amps = 460VA x .778 power factor = 357.88 watts Start up 50 watts = 307.88 watts
115V x 5 amps = 575VA x .778 power factor = 447.35 watts Start up 50 watts = 397.35 watts
115V x 6 amps = 690VA x .778 power factor = 536.82 watts Start up 50 watts = 486.82 watts
115V x 7 amps = 805VA x .778 power factor = 626.29 watts Start up 50 watts = 576.29 watts
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts
115V x 9 amps = 1035VA x .778 power factor = 805.23 watts Start up 50 watts = 755.23 watts
115V x 10 amps = 1150VA x .778 power factor = 894.70 watts Start up 50 watts = 844.70 watts
115V x 11 amps = 1265VA x .778 power factor = 984.17 watts Start up 50 watts = 934.17 watts
115V x 12 amps = 1380VA x .778 power factor = 1073.63 watts Start up 50 watts = 1023.63 watts
115V x 13 amps = 1495VA x .778 power factor = 1163.11 watts Start up 50 watts = 1113.11 watts
115V x 14 amps = 1610VA x .778 power factor = 1252.58 watts Start up 50 watts = 1202.58 watts
115V x 15 amps = 1725VA x .778 power factor = 1342.05 watts Start up 50 watts = 1292.05 watts
115V x 16 amps = 1840VA x .778 power factor = 1431.52 watts Start up 50 watts = 1387.52 watts
115V x 17 amps = 1955VA x .778 power factor = 1520.99 watts Start up 50 watts = 1470.99 watts
115V x 18 amps = 2070VA x .778 power factor = 1610.46 watts Start up 50 watts = 1560.46 watts
115V x 19 amps = 2185VA x .778 power factor = 1699.93 watts Start up 50 watts = 1649.93 watts
115V x 20 amps = 2300VA x .778 power factor = 1789.40 watts Start up 50 watts = 1739.40 watts
Sep 16, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
Statpower PW-1750 Triple Outlet 1750 Watt DC to AC Power Inverter Car Audio Amplifier Logo
2,055 people viewed this question
Top Statpower Car Audio & Video Experts
xxxxxx xxx
Are you a Statpower Car Audio and Video Expert? Answer questions, earn points and help others
