Question about Vizio Televison & Video
I have a Vizio VF550XVT1A. First problem was a flickering screen that ended with the TV turning off. I replaced both invertor boards and the TV seemed to work fine for a few weeks. Now the TV works fine for approx. 30 minutes then the screen goes black but the sound keeps working. This cycle repeats itself after the TV has been left to sit for a few hours.
  • 517 Answers
Good day sir Alfred!!!!
If your screen turns to back after a minutes but the sounds is normal..That problem is very common to all flat panel specially to LCD TV..
OK,I need to know first if your TV having a back-light when the picture went out after a minutes.If that so the possible problem is T-CON board (this board is the responsible to produce a video on all LCD TV)..
If you don't have back-light the problem is inverter board again..But before you order or install new inverter board try to find why the inverter board gone only on few weeks after you install it..the possible problem why the inverter board faulty for the short period of time is higher/lower input voltages (24vdc) comes from power supply..try to check it using volt meter or multimeter tester..it should be read 24vdc on meter..let me know if the voltage drop or higher to 24..
If the 24vdc is fine the only problem is the condition of inverter board maybe its used or partially faulty when you buy it..
if you have more queries and clarification regarding my solution please feel free to reply on this tread...
Hope it helps..
Thanks for using fixya..
Posted on Feb 19, 2012
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My screen is flickering on and off on Vizio LCD TV? I was wondering if it was the main board or the T-Con board.
Flickering can be either with the fault to its back-light inverter or with its main power supply regulator board.
Sep 25, 2015 | Vizio E320i-A0 32 Class LED Smart TV
My Vizio VF550XVT1A shows the picture in the top 1/4 of the screen. The bottom 3/4 is lined and static. I think it's the T-Con board. Any advice?
yes tried to re seat the LVDS cable first, if can not get with re seating the cable check for cold soldered parts in the t-con board otherwise just replaced it.
Aug 16, 2012 | Vizio VF550XVT 55 in. LCD TV
Vo42l no picture. please help!
I had the same problem. No picture but sound. When I turned on the tv, and shined a flashlight around the screen from about 3 inches away, I could it was displaying something.
At first I replaced the main board which has 0171-2272-2604 stamped on it. You can google Vizio VO42L service manual and get a pdf which will show how to remove the back. I got the board from TSM www.tristatemodule.com3642-0482-0150 3642-0482-0150 Vizio TV Module, main unit, 0171-2272-2604, 3642-0482-0395, VO42LFHDTV10A 1 $88.95 $88.95
Order Notes: None
SubTotal:
$88.95 Shipping: USPS Priority $20.00 Tax:
$0.00 Total:
$108.95 However, after I replaced this board I still had the same problem. So next I replaced the Invertor boards. There is a Master and a Slave board to the right and left sides of the main board. I ordered these from Coppell tv.
on Ebay.
6632L-0470A & 6632L-0471A INVERTER REPLACEMENT SET - NEW, OEM, WARRANTY ( 110882329800 ) 110882329800_1.jpg Paid on Jun-08-12
$49.99 -
$49.99
USPS First Class Package Estimated delivery: June 13, 2012
These are compatible replacement inverter boards and work well. All I had to do was bend a tab on the aluminum cover that goes over the boards. After installing these inverter boards the Vizio display works. I started with main board replacement because from what I read online, the problem was either the mainboard (which had the most posts) or the inverter boards. So I picked one.
Install tips:
Download the PDF Service Manual VO42L FHDTV10A_LPL,AUO Service Manual.pdf for some help with the back cover.
When you take all the screws out, set them aside in the same pattern they were on the board for ease of putting the back in.
I was not able to remove the connector on the Ribbon cable between the master and slave invertor, so I left it attached and carefully undid all the tape and removed the boards attached. I plan to send the old boards to Coppell TV (really nice to work with) for their re-use.
I hope this helps.
Feb 27, 2012 | Vizio VO42L 42 in. LCD TV
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,
First of all, thank you for posting your question here at Fixya.
Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.
If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.
Hope I helped you.
Have a nice day!
Good luck and take care!
Jdvillanueva
Dec 21, 2011 | Vizio VU42L 42 in. LCD TV
I have a vizio e320va that when turned on the backlight flickers repeatedly with picture in and out then starts blinking with vertical lines then the screen goes black and the power stays on, This is all...
The tv is having a problems with the board called T-Con board it is dying and the problems.That why the tv is not sustancening the tv pictures for those coded pictures pixels by the T-Con board to stay on to the tv LCD screen panel.This tv problems only causes by the tv T-Con board it is dying only if the tv problems came on to the tv by itself only.If these problems causes by u or an object by outer forces by hitting to the tv LCD screen panel itself.Now the tv LCD screen panel itself it is dying and the causes.Than the tv it is not repairable,tv now only can it to do a replacement of the tv whole LCD screen panel itself only.Not practical because the tv LCD screen panel are 90% important to the tv and the cost of the tv.If u replacing the tv LCD screen panel itself will cost the same as a new tv.The tv is under a year old,why don't u just call Vizio corp. and take ur tv warrenty repair.
Sep 26, 2011 | Vizio E320VA 32 in. LCD HDTV
My Vizio 32 inch has a black screen. The Vizio emblem doesn't turn white when powered on. I have already replaced the power module and the inverter with no success.
I have had the same problem. I called vizio they told me how to reset my tv. It did not help me, However, maybe it will help you. They said turn the power off, Unplug it hold in power button for 30 seconds then plug it back in and power it back up. My white light flickered and then nothing. So I am going to end up buying a new tv all together.
Oct 11, 2009 | Vizio VW32L 32 in. LCD HDTV
Open Questions:
Televison & Video Logo
117 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
