Question about Nintendo Video Game Consoles & Games
Can't connect to wireliss internent wifi
Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Mar 24, 2013 | Video Game Consoles & Games
Connect DWLG810 with Imac
Run an Ethernet cable from the iMac to the router.
Sep 22, 2012 | D-Link AirPlus Xtreme G DWL-G810...
Internal 3g modem not working
HI...........................
YOUR SOLUTION IS
1. The missing WiFi adapter you're looking for is the Broadcom 4313 (802.11b/g/n). download the drivers for it.
If that doesn't work try goggling for the HP package called "sp47895.exe"
2. Install the driver and reboot your machine
If it still doesn't work:
3. Install the HP Connection Manager. This can be found on the HP driver page for the ProBook 6560b.
4. Open HP Connection Manager, and enable the WiFi card (if needed).
REGARDS,
SHAMPA SAHA
Oct 25, 2011 | HP Computers & Internet
There is a slot for inserting SIM card under the battery on my inspiron 15r n5010. I want to know how to set up drivers/firmware and software to set up internet access via 3G network using a sim inserted...
The SIM card holder is there to support an OPTIONAL 3G wireless broadband card: it is not a standard feature and setup will depend on the brand of internal 3G broadband card that is installed.
Compatible internal 3G mini-card may be quite expensive and using an external device (such as Pocket Wifi which is a 'MIFI' device which can conveniently be connected to your PC/Laptop via a secure Wifi connection) might be a better alternative.
Hope it helps.
Sep 24, 2011 | Computers & Internet
My laptop connects to wifi when I first turn it on for about 5 mins then disconnects and says none are In range and will not connect again. If I press fn+f8 off and then on it connects briefly and...
If you are using an internal WIFI card, go to Control panel . System/ device manager and see if, under the network tab (network with a + sign next to it) the wifi card appears and more importantly, appears with a yellow ! mark next to it. If it does, it indicates there is a problem with the device.
On the base of the laptop. you will find a cover plate, open this and check that there are two wires coming from the card, one black and one white, see that they are connected correctly.
After that, and I'm guessing that your laptop is possibly an HP, or Toshiba or Dell, I would think that the internal card or card circuitry has failed or is failing. Your best option would then be to obtain a USB wireless dongle and use that instead,as replacing teh card sometimes only offers a temporary solution
Jul 26, 2011 | Computers & Internet
Wireless connectivity is it possible on the EL1352G
Greetings - Looking at the specs of the machine at the E-Machines website it doesn't appear to have any internal slots for a WiFi card upgrade.
However, there are plenty of USB ports available and an inexpensive USB WiFi dongle ($15-20 USD) would work just fine. Doesn't matter which one, as long as it has drivers for Windows 7 (which would be any recent USB WiFi hardware).
Regards and thanks for using Fix Ya.
Mikeywaf
May 04, 2011 | eMachines EL1352G-01w (884483537679) PC...
I don't have wireliss
use usb adapter to wireless your laptop
Dec 09, 2008 | Computers & Internet
Wireliss
Make sure your wireless is on, disable WEP on the router and see if you can connect, if you can try againwith WEP. If this fails try and use the hex key instead of the WEP password set up on the router. Also make sure that your router is doing DHCP over WEP or you won't be able to resolve web pages even if you are properly connected to the Internet.
What is WEP and WPA encryption
WEP is like a clear connection with no encryption only to get this connection you need to enter key number and password.
WPA is more like encrypted connection and to that also you shall enter key number and password.
In today's wireliss connection speed there's no differences and you better use WEP since they got less connectivity problems
Nov 19, 2008 | Computers & Internet
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
