Question about Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome...
How to remove the spout assembly for a price pfister 34 series genesis
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
  • 1584 Answers
SOURCE: Kitchen Sink Single handle faucet ''pressure'' problem
By replacing the ceramic cartidge inside, however to replace it requires dismantling the tap (Mains off of course) and matching a new unit. Usually cheaper to buy a new tap.
Posted on Feb 25, 2010
packrat1948
  • 528 Answers
SOURCE: I have a Price Pfister
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Posted on Feb 18, 2011
packrat1948
  • 528 Answers
SOURCE: We have a new Price
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Posted on Mar 07, 2011
  • 17 Answers
Not to sure I can help on this .....but some models come with a aerator removal wrench, packaged with faucet.......
Posted on Sep 05, 2011
I have a Price Pfister 34 series kitchen faucet with pull down handle. I need to remove the diverter and have removed everything down to the spout assembly but I am unable to get the spout assembly off by...
How did you resolve the problem of removing the spout assembly? We also have a Price Pfister 34 series kitchen faucet and are trying to replace the diverter. Like you, we have removed everything down to the spout assembly, which will not simply lift off. We have tried letting it sit overnight with WD40, thinking it would loosen it up. No such luck. Then tried using white vinegar, thinking maybe there were calcium deposits holding it on. No luck. Please tell us that you were successful and how you got the victory over this stubborn thing!
Aug 03, 2013 | Price Pfister Marielle Kitchen Faucet with...
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
Leakage problem. How to disassemble the tap?
Illustrated instructions for disassembling the faucet can be found here:
http://www.pfisterfaucets.com/Support/Faq/50160000000HivMAAS.aspx
Installation Brochure:
https://s3.amazonaws.com/PricePfister/34%20%20Series%20-%20GENESIS%20Collection.pdf
It is likely that the o-rings have worn or broken down and are in need of replacement. Pfister provides a Troubleshooting Guide to walk you through possible solutions:
http://parts.bdhhi.com/partscatalog_TSG.aspx
Feb 07, 2011 | Price Pfister 34-3LC Genesis Kitchen...
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
Feb 24, 2010 | Price Pfister 34-3LC Genesis Kitchen...
I have a price pfister kitchen facuet for 8 years now and the top is slack what do I have to do
there is an allen key in front under the hot cold indicator,take it off and tighten.
Jun 11, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Stuck spout
theres a little slide clip sometimes that sits inbetween the stem and faucet body look for that it may have one stopping your progress good luck
Mar 29, 2009 | Plumbing
The lever will not stay up
the cartridge is worn
Solution: remove cartridge take to hd or lowes or ace and match up with new and replace
Jan 06, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Price Pfister 34-3LC Genesis Kitchen Faucet with Spray - Polished Chrome... Logo
226 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
