Question about Radio Communications
Unlock uniden uho76sx.nb
Procedure to unlock a uniden uho76sx.nb 40 channel hand-held radio to change it to a 77, channel radio
SOURCE: UBC60XLT Uniden Bearcat hand held Scanner
http://www.uniden.com.au/AUSTRALIA/cs_operating_manuals.asp
Posted on Apr 30, 2008
BillB-SA
  • 2761 Answers
SOURCE: cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Posted on May 21, 2009
BillB-SA
  • 2761 Answers
SOURCE: how do i unlock a radio shack 164 hand held
The PRO-164 is a trunking scanner with many programming options, and attempting to detail the full programming procedure here wouldn't be practical. Rather, follow this link and you can download/print the full operating manual for your scanner.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000164_PM_EN.pdf
Posted on Dec 04, 2009
  • 211 Answers
SOURCE: uniden bearcat bc60xlt-1 channels wont unlock
Channels have to be programmed with a frequency before the scanner will allow them to be unlocked. The L/O indicator should automatically turn off once a frequency is in memory.
Posted on Feb 25, 2010
  • 1274 Answers
SOURCE: Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Posted on Sep 08, 2010
How to adjust the antennae to get signal uniden 538w
doesn't matter what kind of radio the procedure is the same.First you need an SWR meter.now hook it up properly and take a reading on channel 40 ,write it down then channel 1 , write it down.now channel 19 and write it down . If the number on 40 is higher than on 1 your antenna is long and it has to be adjusted take the allen wrench provided with the antenna and loosen the tip.Bring the tip down about 1/4 inch at a time checking both channel 40 and 1 as you do this . onnce you get a good match then you are ready to go.
Aug 29, 2014 | Uniden Radio Communications
My uho76sx keeps showing up busy and wont recieve
Internal fault, take to shop.
check make sure all wires are connected and non loose before.
Aug 10, 2014 | Uniden Radio Communications
Can't unlock channels they are all showing l/o.
Look to see on the keyboard that has a button that looks like a key with a
border around that button. That'll be you L/O button place the scanner on
Manual then keep pressing Manual for each channel. If you see the letters
L/O << looks like that press the lock out key the those letters "L/O" Should
Disapear.. Keep doing those steps untill all channels a clear.. I say this
because this is how my Uniden 30 channel hand held works..
Yours may work diffrent? Hopefully it works the same.
Jan 22, 2012 | Uniden BC60XLT-1 Handheld Scanner
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
Midland 77-250k No RX nothing, TX perfect on
Best course of action is to ship it in. www.Dodgem250.com
Apr 10, 2010 | Midland 77-250CXL 40-Channels Base CB...
Out of range
Unplug it - take battery out of hand held unit - for several minuets..
Put it back and power up..
If issue still there - there is a channel selector on the hand held unit.. Try changing channels..
If the battery is week in hand held this could happen.. These batteries last around a year +/-.. You can get a replacement online,, WalMart,, Radio Shack..
There could also be interference in the area..
Have a great day !
Oct 26, 2009 | Uniden Cordless Phone
Need codes to program scanner that is a hand held Uniden Bearcat 30 channel 10 Band Radio Scanner
Frequencies for your area can best be found in databases such as:
www.radioreference.com
or
www.cityfreq.com
Sep 12, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Radio Communications Logo
89 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
