I NEED PARTS FOR BOSE SOUNDDOCK
NEED PART 303293-001 FOR AUDIO IN DC POWER
  • kthorlacius
    kthorlacius Feb 18, 2012
    ANYONE KNOW WHERE TO FIND PARTS?
cjackHD
  • 71 Answers
SOURCE: missing power cable for Bose Sounddock
Repair may the only solution. The new power supply is only slightly different though.. If you don't want to spent the $100 to repair this, you could get the new supply and carve a notch in the top part of the square power input.. Looking at the new power supply, the top is a bit taller and arched but the same specs..
But the new power supply is still expensive. (I think $60+) So for an additional $40 ($100 total) you can get a new supply retrofitted on to the old input. It's worth it- you get a new 1 year warranty, and they put the new Apple dock connector on there (USB charge pin) as well as the power supply, so you can use current iPods as well as old. (Your SD currently won't support- iPhone 3G, iPod Touch 2ng gen, or iPod Nano 4th gen.. it will after a repair)
Posted on May 28, 2009
SOURCE: docking cradle in bose sounddock
Hi
To fix this you will need to have the dock/cradle re-soldered. I know someone who does this and does not charge a fortune. If you would like to get it fixed then let me know,
Steve
stevieoke@gmail.com
Posted on Sep 09, 2009
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
  • 51 Answers
SOURCE: I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Posted on Feb 22, 2010
  • 16 Answers
SOURCE: i need this part for my sounddock 282490-001
Invebo.com supply replacement parts for all SoundDocks.
Posted on May 13, 2011
Bose SoundDock got wet
No! the Bose unit would need to be serviced by them, there are no authorized technicians outside of the factory, plus they have the needed parts.
Apr 08, 2012 | Bose SoundDock Portable Digital Music...
Were q ifind parts for mi bose sonuddock theres no audio comen out
Hello, contact www.Invebo.com. they support the Bose Sounddock and also sell the USB charge upgrade kit to enable youto charge the Iphones on a Sounddock Original.
Aug 09, 2010 | Bose SoundDock Digital Music System for...
Missing power back bose series1 sounddock
If i'm not mistaken you can find those on Bizrate.com.
Sep 04, 2009 | Bose SoundDock Digital Music System for...
Bose sounddock remote and ipod menu functions
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan. If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
Jun 22, 2009 | Bose SoundDock Digital Music System for...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Missing power cable for Bose Sounddock
i did the same thing.... i worked for ccity and when we were closing they were about to throw away the display soooo it found its way 2 my car... there was no power port... call bose and go through the automated bs and tell the customer service rep ur power cable died and u tested "ur friends power cable" and it worked fine... tell them u need both parts and if its like my item it should still b under warrenty and they will ship it for free. if not u can just order the parts.
Aug 02, 2008 | Bose SoundDock Digital Music System for...
91 people viewed this question
 Grubhead
Grubhead
