Question about Sanyo Televison & Video
I have lost the remote control to the sanyo DC-HT818 home theatre system. Have tried numerous universal remotes to replace it and they won't work; any suggestions of which sort to use or where to get a new one?
SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
Posted on Jan 09, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
PaulTulsa
  • 14 Answers
SOURCE: sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Posted on Feb 17, 2008
IrishDruid
  • 2712 Answers
SOURCE: Giant Omnitech remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
szwaan
  • 209 Answers
SOURCE: remote control or universal remote that works on my durabrand home theater system 2004 model # HT 3915
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
Posted on May 10, 2008
I have lost my tv remot
Kamlesh, you can purchase a universal remote for your TV just about any where, even the buck store. Read packaging to see if compatible with your make. See links for remotes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remote Controls
universal remote
http://www.walmart.ca/en/electronics/tv-home-theatre/home-theatre-accessories/remote-controls/N-1548
TV Remote Controls
Mar 05, 2016 | Televison & Video
Rca rtd 255 remote universal?
A universal remote that has "code search" capability can be used to find a code that will work with your RCA home theatre. If you search through all codes contained in the remote without success, you may have to try another universal remote because all universal remotes do not contain all codes for every device.
Oct 24, 2014 | RCA RTD255 DVD Home Theatre System System
I am looking for a remote control for Sanyo home Theatre system DC-TS780 9serial no: P4721606 BA. mine was stolen.
USD25 for the
remote control We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 02, 2013 | Sanyo Office Equipment & Supplies
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
Need codes to program universal remote for my Sherwood AV5050R home theatre
dont have book how or what do i do to program my remote lost my book
Jul 28, 2009 | RCA Universal Remote Control
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo DWM-2500 Subwoofer bass output
You cannot access the bass settings with the remote. The remote that comes with the DWM-2500 is Sanyo Part #RB-TS760MT
Oct 28, 2007 | Audio Players & Recorders
Teac PLD2000 Remote control
The best solution for any home theatre setup is a good universal remote. Some of the best ones are from logitech (used to be Harmony). They are capable of controling ANYTHING, and are Easily web programmable. Most common devices and stereos are already on their website so no long configuration is necessary. take a look at logitech's website: http://www.logitech.com/index.cfm/remotes/universal_remotes/devices/372&cl=ca,en for example would be a good buy. go down to your local circuit city or futureshop or such, and ask for a Logitech universal remote, they will likely know what you're asking for. Bigger is not always better, but getting a logitech remote will solve all of your universal remote problems for a long time to come. They're easy and always "updateable" online for the newest equipment available
Aug 14, 2007 | Teac PLD2000 System
Lost remote
You should buy. Each remote come with instractions how to program it. Also you can ask on the store.
Feb 12, 2007 | Sharper Image MC502 System
Televison & Video Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
