Question about Broan-NuTone Kitchen Ranges
Broan nutone NS6500 range hood, fan works but light doesn't
Connected white to white and black to black, fan works but light does not and trips circuit breaker when flipped on
SOURCE: Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Posted on May 14, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
Bulbs blew on my nutone allure range hood new bulbs does not work. please help
Depends what is wrong.To call a repair man will cost a service call before he starts. Check all your wiring and see if there is a short. See what you can do before you call a repairman.
Nov 04, 2014 | Broan-NuTone Kitchen Ranges
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
The fan motor makes a noise but doesn not start rotating, if you rotate the fan the motor kick in and continues to work until it os turned off.
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Jan 17, 2011 | Broan-NuTone Broan Range Hoods Rangemaster...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Kitchen Ranges Logo
43 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
