Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
The computers connected through D-Link got slow internet connections and sometimes cut off. I called my ISP but there was no problem with the internet system. The users of my computers are complaining. plz help me
  • Jeffrey Groves
    Jeffrey Groves Feb 20, 2012
    What are you connecting this switch to for Internet service?
  • arthurlontoh
    arthurlontoh Nov 08, 2012
    I have the same problem with the des-1916A... any suggestion to solve the problem?
  • D-Link Master
  • 7,733 Answers
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Posted on Mar 06, 2015
3 Suggested Answers
kosie007
  • 50 Answers
SOURCE: Does the D-Link DES 1016D 16x10/100 Mbps
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Posted on Feb 08, 2011
  • 8 Answers
SOURCE: The computers connected through D-Link
maybe on an existing network that broadcast the virus to multiplytheir temporary data that make the space backbone network sobusy that cause slow network
Posted on May 21, 2011
How to connect
connect to what exactly? the physical cable connections? or enabling the set up of the switch in the software?
Nov 06, 2013 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to connect a lan
Just connect your router into port 1 and rest of your devices on the other ports. Its just plug and play. Im assuming your router is a DHCP server. If not, configure all your devices to static IP
Aug 01, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
I need to connect dsl to a router then to 9 pc's
connect the router configure the settings give by the internet provider and configure the NAT then u can attach a switch if required and can access....
Dec 29, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Internet and LAN connectivity is disconnecting rapidly
check and make sure that all cable are straight through and that the connectors are good.
Dec 16, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
564 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
