Question about Exercise & Fitness
Pro form consel displays PO and will not start
Turn on and doesn't start. Panel flashes PO
    Top Expert:
  • 12,223 Answers
Dear Sir:
This is probably a 1)faulty speed sensor or 2)speed sensor is not plugged in properly. 3)faulty motor control board 4) adjust the reed swithc. The error codes will differ between makes and models but could be e1.
see the diagram for boths adjustment. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
pro form consel  displays PO and will not start - 2_18_2012_5_01_06_pm.gif2_18_2012_5_01_18_pm.gif
Posted on Feb 18, 2012
3 Suggested Answers
SOURCE: pro-form treadmill flashes po when turned on.
cant get tread mill to slant
Posted on Nov 22, 2009
ercupa190
  • 12223 Answers
SOURCE: My pro form 540 display panel lights up but machine does not run. Any thoughts?
This the following adjustments:
Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
11_29_2011_4_04_13_pm.gifSee the block diagram how the main controller board has 90% aprox of functions of any treadmills. Tight the flexible cable from keypanel vs display board . then Display board vs. Main Controller Board.
Good luck, sincerely. G-d Bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Nov 29, 2011
I have a whirlpool gold fridge and its flashing the po code why and how do I make it stop
PO stands for Power Outage. The fridge lost power for some reason. On my fridge I just hit "acknowledge" and it goes away. I don't own a whirlpool. Here's a page that lists different instructions for multiple different fridges in order to reset everything and turn off the PO light. http://removeandreplace.com/2016/02/02/refrigerator-display-panel-is-blank-not-working-how-to-reset/
Refrigerator Display Panel Is Blank Not Working How To Reset
Nov 15, 2016 | Whirlpool Refrigerators
2000 ford excursion misfire on 2 cylinders #2 & #7
Swapping coils is a waste of time-- as cop ford coils
act up when they feel like it & they do so often,about
one to the entire 8 every year.
I have never heard of moving a spark plug
All those ford trucks are terrible, just to get up in there,
how could you put yourself thru that
Not the coils,your very wrong there
If you have no professional scan tool to use in
Mode #06 --- you buy at least 4 coils from Rock Auto.Com
You start with any cyl you have a code for,if it doesn't
resolve the issue you replace the old coil and walk the
new one to the other codes PO 301 thru PO308
You may have several bad ones
One really bad one will set all sorts of codes
from PO 300,PO 301 thru PO 308, fuel tank sensor
& many others,very strange systems on ford products
I have seen on my Lincoln LS when scan tool software
didn't help & wasn't about to drive around with a scope
on a coil & the wires under the hood blowing around
You have to drive a ford cop ignition at least 20 miles
& they have to get hot.
I have driven for 2 weeks & gone out of state before
they failed
I take 2 coils & my notebook with software, if I go more than
100 miles,I have a travel kit--- that coil issue is so bad
Oct 19, 2012 | 2000 Ford Excursion
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
My net acer zg5 AOA150 doesn.t go. He start only the light "on" but it doesn't go
you need a flash drive fat32 formatted,download the bios update from acer website.copy the flashit.exe & 3114.fd to flash driverename 3114fd to ZG5IA32.FD.insert ur flash drive to the right side usb port. turn on power while holding Fn and Esc key don not release the combination key until u count of 7 sec, when light is on push again the power button then release.it will blink in a minute and the light turn off, don't do anything until it restart. just relax it takes a minute.if you can't download the file e-mail me @ fccaole@yahoo.comgood luck guys! wait for 7 second to release
Jul 30, 2011 | Acer Aspire One AOA150-1784 Netbook
Just had both o2 sensors replaced and now the truck won't shift from 2nd to 3rd gear. Evidently it had been slipping a bit before but now it won't shift into 3rd at all. The tranny is an E4OD......
O2 Sensors --- not related to shifting
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
Need a new guy
Not very professional were they
Jun 13, 2011 | 1997 Ford Expedition
I was told to upgrade Intel pro wireless diver to version 9.0.2.31... How and were do I get that? Can someone help? Also, ones I installed the the software. My laptop's display changed, I went to change it...
You simply need to know the laptops brand & name? Also you get that driver, from the makers web site, Google, name-of-laptop drivers download, & look fror the makers web site, locate and download, and install. The multimonitor is quite normal for a laptop, the LCD is screen 1 & if you connected an external monitor, that would be number 2. You click on 1, and then the settings apply to that one.
Feb 26, 2010 | Computers & Internet
Exercise & Fitness Logo
114 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
