Question about Pantech Cell Phones
Pantech laser broken lcd screen
Where can I get a replacement LCD screen (not the glass, the actual screen)?
  • 355 Answers
You can buy it from any phone repairing shop or you can buy it online from ebay or amazon. search it in google. thanks.
Posted on Feb 18, 2012
  • 4 Answers
SOURCE: broken lcd screen
Step one Take out battery!! to avoid esd (Electro Static Discharge that may ruin the new screen or fry your phone), there are four screws in the corners covered by a sticker material two over the speakers two under in the far corners hidden with stickers. remove those stickers with a sharp flat bladed eyeglasses screwdriver. use a #00 phillips head screwdriver to undo these screws. Look along the edges of the face of the phone you will see where the colored piece meets the gray piece. I used the flat bladed screwdriver and carefully wedged these pieces apart and used my finger nails to carefully separate without penetrating too deeply with the screwdriver (that may crack the internal screen). pull the cover off gently you will notice after you removed the keypad there is a metal cage housing the internal screen gently pry it from the side of the end key You will see a 7 by 3 mm box underneath with gold connectors do not touch these the oil on your fingers will prevent the screen from working properly this is the connection for the outer and inner screen to the mother board on your phone (right side from top view) it may take some effort as mine was tight you will see the screen and zif connector for the front lcd. also the outer speaker is soldered to the lcd circuit pad. Take a picture with a digital camera if you need to desolder from the old and resolder onto the new lcd (this is a pain in the ass and the pictures will help trust me!!!) lift the black clip on the zif connector and remove the screen ribbon while taking care not to pull on the earphone assembly use the flat head to remove the magnet and earpiece noting their orientation for later re installment. de-solder from the old lcd and re solder connection of these components to the new lcd. Place them back into their respective positions tucking the wireso that the cage will not pull on them when you push it down (there is a small gap but still be very careful) Place the zif connector ribbon in the holder and slide the plastic retaining clip back down. Flip the cage into its original position and push firmly into place. re-install the key pad and face plate. re install battery and power on. my screen didnt work at first. i had to press rather hard to get the pins to seat properly on the one and four button area after i closed everything up, where the part is i said not to touch, so dont be discouraged if you put it all together and neither screen works (I found this out after i got rather angry after all that work) This is all a very overwhelming amount of work but i learned a great deal. you may try ebay for a broken env or one with a bad ESN they go cheap <100$ and you can use the screen and speakers without soldering. That would cut the probability of failure by 75%. The contacts are rediculously small 1mm by 2mm super hard to solder properly but everything else was simple. screens are available for 30.00 on ebay they are new but again comes the soldering issues. wish lg would use some sort of pin connector instead of soldering these contact directly to the phone that would make this phone way more easier to fix. hope this helps good luck
Posted on Jan 26, 2008
SOURCE: how to replace a broken lcd screen
any pictures please
Posted on May 15, 2008
SOURCE: How to replace broken front glass on razr v3
The glass is usally attached to the phone through a very sticks substance. all you need to do is carefully peel off the old broken one and put in the old one by sticking it on their
Posted on Jan 18, 2008
  • 3 Answers
SOURCE: need to replace broken lcd screen
http://www.formymobile.co.uk/kc910disassembly.php
Posted on Aug 17, 2009
SOURCE: broken lcd screen on sony ericson w595
http://www.formymobile.co.uk/w595disassembly.php
this site will show u how to do it in picture form .
Posted on Mar 08, 2010
Need a replacement LCD screen for burst phone
Hi, new replacement screen can be found at amazon, here: Finally charging for our multi device world take a look. Wish you best of luck
Oct 23, 2012 | Pantech Cell Phones
Garmin 660 broken screen
Its the LCD glass which has gone bad you cannot change it yourself,
Jul 07, 2008 | Garmin StreetPilot c340 GPS Receiver
My son sat on his Pantech slate and the screen inside the phone appears broken (the plastic screen is not, just the lcd). Can I get a replacment screen?
could still be covered by warranty- for accidental damage- if you have the coverage. consider what it will cost to replace the lcd screen to what it would cost to replace the 'slate'. may be cheaper to replace the phone!!
good luck!
Oct 11, 2009 | Pantech Slate Cell Phone
Broken screen
Hi, It will depend on whether you've broken just the glass, or damaged the LCD.
There's a video of how to mend the glass here on youtube:
http://www.youtube.com/watch?v=ozBunsKT1Y8
Jun 16, 2009 | Apple iPhone Smartphone
ACCIDENTLY DROPPED PANTECH CELL LCD SCREEN WAS BROKEN, NEED TO FIX IT?
yes you do need to get it fixed things like a broken lcd screen can get worse if not fixed, so get it checked out and replaced as soon as possible
Jun 15, 2009 | Pantech Matrix Cell Phone
LCD screen on my pantech matrix is broken
no. your LCD screen is busted and will have to be replaced
Apr 08, 2009 | Pantech U4000 GSM UNLOCKED 1.3MP CAMERA...
Cracked lcd screen
You see cracks in glass that is not generic glass. It is LCD Panel made of new technology.  That glass has few layers and a large amount of liquid crystal dots array built in. There are few polarizer in between LCD Panel. Below is an image having bit details about LCD Panel.
Hope this will clear the concept of LCD Panel vs generic glass.
Jan 10, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
HELP!!!! - Vizio GV47LF LCD HDTV HELP!!! - HOW TO FIX?
When you turn it in, do you get an image? And if it is the LCD screen ( not the front protected glass) then yeah you might as well junk the TV. The cost for a replacement LCD screen exceed the cost of the unit. Sorry about the bad news, just being honest. Turn the television, if the LCD is cracked, then you will see it right away when the television is turned on.
Nov 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Cell Phones Logo
487 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
