Question about Panasonic Microwave Ovens
Panasonic NE-9930 Micowave Oven
All power, but does not heat/cook anything.
SOURCE: microwave oven is getting poer but nothing getting heated up
I am facing the same problem. The light and display is working fine but not heating. I have a kenstar product.
I tried calling the service station in my city but the Phone no. no longer exists.
Can anyone suggest me something on this. Please help.
Posted on Aug 12, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: oven won't heat and shuts down after approx. 20 seconds
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile micowave model JE2160SF001 won't cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden elsewhere, which is very helpful when troubleshooting, testing, and locating components.
If you only need a switch, you can order a universal type
here for $5 postpaid.
Posted on Jul 25, 2009
proartya8765
  • 581 Answers
SOURCE: Have a Panasonic Microwave/Combination
I could not find your exact model but please check out the link below and download the one that is closest to yours.
Hope this helps. good luck
http://www.panasonic.ca/english/customercare/downloads.asp
Posted on Dec 05, 2009
Power comes on but micowave does no cook
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Black Microwave Oven
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Micowave is not heating up, and is making a
It may be a shorted diode in the HV power supply for the magnetron. Open the case to get to the part. Unplug the machine before opening anything. This is normally a high voltage area when running.
Jul 17, 2009 | Microwave Ovens
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
No cook mode
check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Oct 07, 2007 | Panasonic NN-S540BF Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
