Question about Cameras
How to reinstall sony LIRDCSL security camera
Someone cut the wire on my outside security camera. inside the cord there is 1 white covered wire,1 yellow and one with no rubber cover around it. i NEED TO KNOW what each wire is for so i may rewire it to enable again.
t00nz
  • 4738 Answers
SOURCE: camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
  • 1388 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
Gurudristi
  • 98 Answers
SOURCE: Dropped the Powershot A630 camera - still works
So get ready with your screw driver.
I am posting a link below... will give you an idea of how to disassemble a A650... The assembly will of course be in the reverse direction.
Keep the screw carefully... You will only need to understand a part of the whole process.
http://heliodorj.blogspot.com/2008/05/disassembling-canon-powershot-a650.html
Please do rate this solution and thanks for using FixYa.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: Broken battery latch cover
no, is not practical to repair. you can do bigger mass what is now. only what you can do is secure cover with self-adhesive tape. if you not satisfied with this, go to service and pay repair.
Posted on Mar 25, 2009
efs_perpends
  • 1996 Answers
SOURCE: Missing rubber cover for HP R707 Digitol Camera
Please go to this link for an online manual for your camera, by clicking here.
You will find that it includes an appendix B with links to HP accessories and online shopping for HP products.
If you have no luck there, I suggest you contact HP support directly (www.hp.com/support) and make a request by including the model number of your camera and the part number. (Found by looking here)
and possibly here.
Finally, you might have best luck trying to resolve this with a live person on the hp phone support line.(see user's guide for local numbers)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
How do I replace Dyson DC24 plug
Cut off the old plug end with wire cutters. Next, strip off the outside cover of the cord about and inch off. This will expose the black and white wire inside. Then strip off the coating on the black wire and white wire. Take your new plug end and slide the plug over the cord. Use a phillips screw driver to wire the black and white wire to the terminals.
Sep 05, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Vk-m10
Maybe Hitachi will respond to a direct inquiry.
Dec 10, 2013 | Hitachi Cameras
We are experiancing probems with our agua view. The light comes on on the moniter but there is no video coming through. Is there a fix for this issue
i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Jan 16, 2011 | Aqua -Vu Perch Underwater Camera with...
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
I NEED TO SWICH FROM A 3 PRONG PLUG TO A 4 PRONG PLUG.HOW DO I DO THIS?
remove cover plate and observe your old cord has 3 wires the the 2 outside one are the power/voltage 120v each one and the center is neutral...........you 4 cord has 1-black 1-red 1-white 1-green put the black and the red to the outside connections on the block white goes to the center and the green just attachs to the metal casing on the dryer if you are not completely sure get someone who is because if wrong it could cause a fire or burn something in dryer as always in all my advice if you are not sure get or pay someone who is...............fixrguy
Aug 24, 2009 | Dryers
How to switch 3 prong cord to a 4 cord prong.
Aug 21, 2009 | Maytag Dryers
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
Jun 04, 2009 | Lorex SG6153 / Weather Resistant Mini...
Aqua vu underwater camera
i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Aug 09, 2008 | Aqua -Vu Perch Underwater Camera with...
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
