Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Control lock will not turn off
How do I shut off the control lock? I cannot get my washer machine to run because it is stuck on control lock. I unplugged it and plugged it back in and it still will not work. Is there a reset button somewhere?
  • lawnmd Oct 26, 2008
    Thank you!!!! Its fixed and running.
This happens to me when i or someone else leans up against that button. easy fix thou.
hold that far right button down as the guy above me suggests.
Posted on Oct 27, 2008
  • Whirlpool Master
  • 2,651 Answers
The far right set of buttons lowest one, if you looked closely is marked "control lock" hold for 3 secs, the control light will go off
Posted on Oct 26, 2008
How do I get my lg waveforce WT5001C washer to turn on? The power went off and now the washer lid is locked shut and none of the lights are on. I checked the wall plug and it is fine.
Having the same problem with my LG WaveForce top loader. Power went off and now lid is stuck shut and machine will not turn on. Power outlet is fine.
Aug 27, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
My front load kenmore washer is stuck on control lock when unplugged it start at 14min when plugged back in on the spin cycle and when it reaches 2min the machine shut off and the control lock flashes door...
Hello & Welcome to FixYa
This is a common issue with washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the DRAIN/SPIN button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Oct 04, 2011 | Kenmore HE3T Washer
Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 26, 2010 | Whirlpool Washing Machines
A maytag mah3000waa front load washer when it is started it runs for about ten seconds then stops. push start again it runs another ten seconds and quits again. it also does this in spin. could this be the...
The service manual says do this:
Runs For Five Seconds Then Shuts OFF:
Suspect a communication problem between
motor, the motor control board and the machine control board. Check the motor and
motor control system by removing the JP4
connector on the motor control board. Set
the timer dial into the delay cycle and then
press the push to start switch. If the motor
operates and the washer goes into a 50 rpm
tumble, then the source of the problem is the
RD 30 wire leading from the motor control to
the P4(2)/RD30 connector on the machine
control board. When the machine control
tells the motor control to run the motor, it
monitors the red wire to determine if the motor is actually running. If the board does not see a return signal, the washer will shut down.
If RD30 wire is making contact, then suspect
possible problems with timer input circuits
Tumbles Only:
When the door lock mechanism is in the
"locked" mode, the wax motor has extended,
forcing the latch axle to engage the door lock
enable switch. This ensures the door is fully
locked and the switch can then complete the
signal back to the machine control board indicating
the door is locked. Check connector
P3(7)/YL 36 wire to verify if the terminal is
making good contact to the board terminal.
Check the door lock enable switch for continuity
when the button is depressed. Replace
door lock mechanism if necessary.
IT appears to be inputs and not the control board.
If you need more assistance just repsond here and I will reapond accordingly.
Thanks for using FixYa.
May 21, 2010 | Maytag MAH6700AWW Neptune Front-Load...
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
until the control is unlocked.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When running a cycle the water doesnt shut off causing it to over flow, but the pump is working
Problem with water level switch or the clear tubing running from the bottom of the outer tub into the control panel.
Also if the water won't shut off even when you turn the washer off - problem is in the water valve stuck open.
Oct 14, 2009 | Kenmore 22422 Top Load Washer
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal De
