Hi, I came across one of your posts and had a question.  I have a p50hdtv10a, it  died, now the screen flickers and turns off. I've noticed that the led on the main board's power input shuts off and then a relay on the power supply clicks and the tv shuts off, the ysus board is clicking while all this goes on, the pattern of the flickering and the clicking on the ysus board are dead on. Which board could cause these symptoms?
  • 8,617 Answers
The transfformer and Transistors on the Y sus . Replace the Y sus and you should be fine. There were 4 different Ysus boards used in that model. Contacting the guys at www.tvcircuitboards.com will assure you get the correct one for your model. If you need assistance just send a email to them at customerservice@tvcircuitboards.com
Posted on Feb 18, 2012
  • 597 Answers
SOURCE: My Vizio P50HDTV10A display is a black flickering
main board
Posted on May 31, 2010
eagle338
  • 4889 Answers
SOURCE: I have a sony 50"
The flickering lines on the tv are usually caused by faulty sustain boards. There are usually two of them in most models and replacing them both should resolve your issue(should cost you about 200-250 bucks for both parts). Replacing them should not be too tough if you have some know-how of electronics. Otherwise please get me your zipcode so that I can help you find a local tv tech in your area who can do the job for you.
Posted on Oct 23, 2010
SOURCE: white flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
Posted on Dec 23, 2010
  • 1156 Answers
SOURCE: VIZIO P50HDTV10A PICUTURE FLICKERS IN
HI, you can do these troubleshooting steps and get back to me..
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Posted on Jun 17, 2011
diodeic
  • 1622 Answers
SOURCE: vizio p50hdtv10a screen flicker
CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
I hope this will help to solve the problem....
Posted on Sep 09, 2011
I've accuired a Vizio P50HDTV10A that was dropped.
Yes, do not bother as it sounds like the display panel is damaged--time for a new set parts cost wise. Since you have nothing to lose open and examine it with the faint hope a plug is loose or off or a board cracked,,,faint chance only.
Oct 23, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
What's your prI have a VIZIO p50hdtv10a that does not turn on. I think on accident my son inserted a unknown object in the port sevice 1 and since then it has not turned on. What part could be bro
Just look at the port and find out whether anything stuck there, especially any metal part or wire. Change the input device to some other that you are sure works. Try changing the input selection to all available. Also check whether the Power Cord has come off from the rear by mistake. Check whether the power outlet is on. If none of these work, this may be referred to a qualified service technician.
Jul 29, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Can I fix a flickering band on VP2250wb?
It sounds like one of the backlights are going, or one of the inverter transformer and there are two capacitors near the inverter transformers that do give trouble. The monitor would need to be dismantled to investigate the problem and it will involve money, since it is four years old I would be inclined leave it alone until a new one is required.
Apr 15, 2012 | ViewSonic VP2250wb LCD Monitor
Flickering shadows bottom 3/4 of the screen flatscreen vizio tv
Hello
To replace the CCFL lamps, you have to disassemble the LCD module. It is a very skilled work, as CCFL lamms are very brittle. and should be handled carefully. It will be best to get this set repaired by any expereinced service technician.
Mar 05, 2012 | Vizio VO47L 47 in. LCD TV
96' 3.2 Acura TL dies while driving now won't
i have posted this solution before, I will give you the short version. On the steering column, under the left side of the cowling, on the opposite side directly across from where the key goes in the ignition,... there is a wire loom screwed to that end with 2 screws, remove this and clean the inside of both sides CAREFULLY, dont break anything. expensive dealer part! just scrape it lightly and wipe a little, carefully re assemble, dont bend it, dont screw it back in too tight, you cant make it go together any closer than it will. This solution solves a number of odd problems attributed to ACURA quitting , battery not charging, lights flickering turn signals not working, a lot of things, so i think everyone should do this to there ACURA, and its EASY!
Feb 07, 2012 | 1996 Acura TL Series
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Multiple vertical white lines
hi,
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrlbt-xl-eax35683901-ebr35855501/
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrrbt-xr-6870qsc107a-6871qrh073a/
If you need any more assistance feel free to contact me through fixya.
Ajin
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi: My acer56c is eight years old and humms while turned on as well as getting the horizontally linear blue occasional flash across screen.The colors when turned on are not 'initially' accurate(Orange...
if its a CRT monitor then you wont have a problem, the all get decrepid and loose color flicker then eventualy die.
i say use it till it dies then get a new one or get a new one befor it dose damage to your eyes, a nice TFT screen will do.
Jul 03, 2009 | AcerView 56C (White) 15 in.CRT...
50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Mar 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
