Question about Haier XQJ50-31 Top Load Washer
E2 error but I did close the door
The machine stops during washing cycle with the E2 error (indicated in the manual that the door is not closed.) But I closed the door and it was closed completely. I tried pressing the door at the corner but it didn't help. I tried to unplug it and restart it but it ran the same with the same E-2 problem. How do I fix it? Thank you so much.
  • 3 more comments
  • Anonymous Nov 30, 2007
    yes
  • Anonymous Mar 04, 2008
    I am trying to start the washer but it give me The E2 error . What should I do?
  • Anonymous Mar 27, 2008
    i keep getting E7 does anybody no what this is. on my haier machine. I dont have a top loader. just a normal machine.
  • Anonymous Nov 14, 2008
    error code e2, machine won't start
  • cat2660 Nov 14, 2008
    I have tried everything to trigger this spring to connect with a sensor to turn on the washher, whats next?
This machine is very problematic. I had the E2 Error as well. The problem, like dddd501 said, is with the spring in the left hinge of the top lid. It probably gets loose after some use. I solved this, after many trial and errors by wedging a piece of thick cardboard in the gap between the top lid and the surrounding machine in such a way as to PUSH the top lid BACKWARDS into the direction of the control panel. This, I presume, will force the spring into whatever sensor that detects the top lid is closed and removes the E2 message.
(Diagram) View of washing machine from the top: Wedge the thick cardboard at the gap marked XXX. Good luck.
_________________________________
| Control Panel |
|---------------------------------------------------------| LH = Left Hinge
| LH RH | RH = Right Hinge
| || Top Lid || |
| ||=XXX======================|| |
Posted on Sep 20, 2008
I think there is a problem with the spring that is attached on the left hinge of the door. Try elevating the door for a couple of milimeters with some rubber object. that should help
Posted on Jan 24, 2008
    New Friend:
Mine was just a matter of pulling the lid towards me.
Posted on Aug 03, 2013
SOURCE:
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Starts to wash and it stops and i have E 2.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | Bosch WFMC 3200 Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
It start set time and then stop and show error de..
This indicates that you have a Door Error and can be caused by the door not being closed correctly, being pushed open during a wash cycle due to an extra heavy load (typically with towels or blankets), the door switch assembly is loose, the door switch assembly is defective and needs replacing, and least likely there is an on board controller fault. Try closing the door and pushing on it near the door lock to see if the error can be temporarily cured, if not then you will need to check the above and probably call in a service engineer to repair it. While this error exists the machine will not work as this is a safety design feature of the machine to prevent injury.
Oct 24, 2009 | LG Washing Machines
Haier XQJ50-31 Top Load Washer Logo
993 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
