Question about Rex Sewing Machines
How to adjust tension on a rex 26-188
Industrial 26-188
How do i adjust the bobbin tension on a mini rex sewing machine
Sorry, am unable to locate much information on your machine. However, something in the following may be helpful.
You may want to read through some of the reviews as there are some hints:
Amazon com Smartek Mini Sewing Machine Cordless Red
How to Use Mini Rex Sewing Machine eHow
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwjjjan6v43RAhVp04MKHdB2DCIQFggqMAM&url=http%3A%2F%2Fwww.tivax.com%2Fmedia%2Fdownloadable%2FUser%2520Manual--LSS-202.pdf&usg=AFQjCNGYbItSX6kGJyUY9pmNJnptm9RfWQ&cad=rja
Or contact them directly for information:
General Information
info@smartekusa.com
Dec 24, 2016 | Rex Sewing Machines
Can I contact Rex about my type-r or get a manual. Can't find one
Rex Sewing Machines
i cant find any for free,here is their adress and number,,
Rex Sewing Machine Co Pvt Ltd 245, Lind Road, Industrial Area A, Ludhiana - 141003, Oppooste State Bank Of India +(91)-161-2604925, 3048420, 3048450
Apr 20, 2015 | Rex Sewing Machines
How to adjust timing for Rex blindstitch hemmer
As long as your machine is not skipping stitches the timing should be fine. Three things to check: take your thread tension assembly apart so you can remove the discs and clean. Debris often gets between them and causes irregular tension. Next check the point of the looper to see if has a burr. If so take 600 sandpaper or crocus cloth and remove. Last-Check the upright pin that the looper passes--it too may have a burr.
Mar 24, 2015 | Rex RX-518
Where can I get a downloadable manual for a Rex 11-155R
www.industrialmanuals.com
Try the above .
Rex-Hitachi-Industrial-Sewing-Machine
Jun 04, 2014 | Rex RX-518
I need a replacement bobbin for industrial rex 11-155r
Cutex Sewing has them online. Here is link to 100 but they have them in smaller quantity also. http://www.cutexsewingsupplies.com/servlet/the-2390/100-INDUSTRIAL-SEWING-MACHINE/Detail
They also have the needles DPX17 and Bobbin Cases too.
Jan 15, 2011 | Rex Sewing Machines
In need of welt foot for rex 26-188 sewing machine. Is there one that is available for another machine that will work?
Well I'm not sure if this is a solution but, most walking foot machines are either like the Juki 562 or 3 and the Singer 111, 211  or newer models. REX's are particularly original, they should be using a very similar welting foot. Many industrial sewing stores in LA have them.. Kyle
Mar 26, 2009 | Rex Sewing Machines
RX 518 portable hemmer
If you are the one I replied to about a URL for your manual I was wrong this is the right one:
Try this URL:
www.sewingmanuals.net
Feb 27, 2009 | Rex RX-518
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
deaususa
ray gallant
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
