Question about Electrical Supplies
Wiring a ceiling pull switch
Hi. I want to add a new light to an exisitng ceiling rose (my lights are on a loop-in system). The new light will be in the loft. I will also include a pull switch to turn on/off this new light. How do I wire the pull switch inline?
  • 417 Answers
The pull switch can be wired in line at the required position by removing the outer insulation on the cable sufficiently to allow for the intended live conductor to be cut and one end connected the switch in terminal and the other to the out terminal.
Make sure that the cable is not live or connected to the supply in any way while you are working on Please remember to rate this
Posted on Nov 03, 2008
How do i wire a new light switch and ceiling rose from a socket
not sure as to what you want to do, if there is a switch there turn off power to old switch and just replace it, as for ceiling rose??????????
Oct 15, 2011 | Home
Connected fan and rose into pull swith one set of lights working fan and other set of lights not working
Your not being very clear in your explanation. Sounds like your hooking up a ceiling fan with lights. Recheck your wiring.
Sep 01, 2010 | Home
The correct why to wire up a cieling fan
The usuall wiring for a ceiling fan is black to black, white to white , and red house wire to the other fan wire, sometimes blue. If you only have two wires from the ceiling, then it is still white to white and black to black, but add the other fan wire to the black wires ..
Jun 17, 2010 | Solar 2-wire Pull Chain Light Switch For...
I want to add a light in my room which is apart of the upstairs lighting circuit. The only problem that I have is that all the terminals within the celling roses in the upstairs lighting circuit are being...
The problem is that you need to understand that the red and black wires may not be power and return. The main red line is broken at a point and a new cable run to the light ( red + black) or (blue+ brown) this is merely the switch circuit fore that light. So if you mistake the two points it may be that what you have is red+red to your globe. ( Is that clear?) you would need to find the common black + the red to take power to the Red+black to your new ceiling rose, but breaking the now new red wire somewhere and joining in a new red_+ black that goes down to the switch
Use a power checking device as sometimes in some roses where multiple circuitsw feed fom Black and Black can be live
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Electric Door Light Switch
How do i replace a pull cord with light switch
Ok so, L (line) N (Neutral) and E (Earth ground), and no idea what this rose is. I suppose you mean Junction Box when you say JB. You can use the original junction box for the wall switch connector, but the Black and white wires coming from the switch must be disconnected from power to be used, if power is already present in your light's original junction box (which is usually the case when using a pull switch light). Then you connect the white and black wires to your wall switch and use them to break the circuit at the light itself by wiring it between the light and the power lead.
Mar 24, 2010 | Plumbing
Ceiling rose nt working
Look for the manufacturer's wiring on line or if the product is still available ask a merchant to permit you to copy the schematic from a similar product as yours. If they want future or continued service to you they will most likely accommodate you.
If that does not work, have a certified electrician look at it to sort out the three black and four earth wires.
Nov 13, 2009 | Cooper Industries Cooper Wiring 2158V 3...
Downstairs toilet light switch needs rewiring
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Dec 07, 2008 | Electrical Supplies
Lighting circuits
Can you draw out what you think the wiring looks like? Maybe I can help from there.
Nov 02, 2008 | Kitchen Appliances - Others
Electrical Supplies Logo
572 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
