Question about RCA TruFlat 27F520T 27" TV
Remote control I lost my remote control and i can't get to any input to watch dvd's
  • 903 Answers
Use dvd player without remote control
just able to watch the first show of my series dvd. is it somehow possible to watch the other shows of the dvd AmanStino Mouse Pad with Gel Wrist Pad grey9 0 7 8 AmanStino
Nov 30, 2016 | Teac Televison & Video
The input control button not working
Usually there is a input button on the TV itself.
Oct 16, 2012 | Toshiba Ct-90302 Remote Control
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Put a dvd in want to watch what to do
Hi. Press the input button on the TV remote to get the TV to the right input for the DVD player.
Mar 14, 2010 | Samsung AH5900092W Remote Control
My remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
Nov 15, 2009 | RCA RCU300WBL Remote Control
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
Jan 02, 2009 | Logitech Harmony 890 LCD Remote Control
Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
Dec 15, 2007 | Symphonic ST419E TV
RCA TruFlat  27F520T 27" TV Logo
250 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
